oil cooler elimination
Old Jan 12, 2009, 05:42 PM
skatermsmn's Avatar
Im eliminating the oil cooler for a week or 2 untill I can get my other oil cooler. How would I go about this, Can I just block the two holes or do I have to have them connected? If anyone has pics, that would be greatly appreciated.
Old Jan 12, 2009, 05:48 PM
taenaive's Avatar
I would just block it. There is a thermostat for the oil cooler so It wouldn't flow till engine gets warmed up.
However, you shouldn't drive too long without the oil cooler. your engine will overheat.
Old Jan 12, 2009, 06:00 PM
skatermsmn's Avatar
I have heard of people driving there car daily removing there oil cooler. I live in MN and its pretty cold, I only plan on running this till I can get a cooler. This is my only car.
Old Jan 12, 2009, 06:35 PM
skatermsmn's Avatar
pics would help the most
Old Jan 12, 2009, 06:36 PM
VRSF Tiago's Avatar
Loop the inlet & outlet, don't block them.
Old Jan 12, 2009, 07:13 PM
chaotichoax's Avatar
not true
Old Jan 12, 2009, 07:18 PM
VRSF Tiago's Avatar
Originally Posted by chaotichoax
not true
+1
Coolant keeps your engine cool, not oil.
Old Jan 12, 2009, 07:21 PM
vboy425's Avatar
yeah just plug it up. either way when you start your engine gain, it would be safe to prime it first by disconnection the crank angle sensor. crank couple of times and check your oil level before plug that sensor back in and crank it on for good.
Old Jan 12, 2009, 07:24 PM
skatermsmn's Avatar
So I can just plug em both. I dont need to run a tube in between the two?
Old Jan 12, 2009, 07:31 PM
VRSF Tiago's Avatar
LOOP THEM.
Plugging will cause excess oil pressure. If you're not driving/starting the engine plug them but if you're driving loop them.
Old Jan 12, 2009, 07:42 PM
itsme4g63's Avatar
Originally Posted by tvieira24
+1
+2, unless you're really pushing your car to the limit you won't need it, so your 2 week oil cooler hiatus should be fine. Just try to find the correct fittings to close it off, I'm not sure the thread size but it should be along the lines of m14 X 1.25 or M16 x 1.25, best if you could take it with you to a parts store.
OT, but dsms run oil-cooler-less and have way more air restriction (the evo has a huge openings in the bumper whilst the dsms have smaller ones) than the evo and still run moderately cool.
Old Jan 12, 2009, 07:51 PM
VRSF Tiago's Avatar
The DSM's actually run a water cooled oil filter housing so it's not completely oil coolerless
Old Jan 12, 2009, 07:54 PM
itsme4g63's Avatar
yeah thats what I mean my bad, only one model year dsm ran a oil cooled oil filter housing and that was the 1990, alot of dsmers actualy use the external oil filter housing from that model year and either get aftermarket or stock oil cooler to help cope with the factory restricted bumper, or hack it out lawl.
Old Jan 15, 2009, 04:23 PM
hlm
hlm's Avatar
i woudl just wait until u get ur new oil cooler that way u dont have to worrie about it.
Old Jan 15, 2009, 04:28 PM
2k4EvoVIII's Avatar
Just plug them. You wont have any problems doing this. All the drag racers do it and it will NOT overheat unless maybe you are road racing. It also will NOT change your oil pressure so dont worry about that either. You are more then welcome to talk to Buschur he will tell you the same.
Chris
Quick Reply: oil cooler elimination
