Need Help Guys Real Badly!!!
![Unhappy](https://www.evolutionm.net/forums/images/icons/icon9.gif)
my car wont start , the starter works fine and i have charge in my battery , the only upgrades ive done to my car is a turbo timer , greddy profec B EBC , and took out the stock bov from the intake hole to make that woosh sound and covered the intake hole with a filter it worked all fine till (a few days after)i was working on the car i dont remember what i was doin , but i knw for a fact it had to do with the turbo timer , bov , or EBC , i was listen to music at the same time , then the music turned off , i noticed that my cars battery died i was starting it , it would make this clatclatclatclat sound fast , my dad said that happends to all cars that dont have enough power to start the spark plugs , so ok i replace the battery now the starter works but the car wont turn on(idle means car stay on right?).....y?i tried starting the car while pumping the gas ,no works , checked all fueses ...........help plz![Confused](https://www.evolutionm.net/forums/images/smilies/confused.gif)
no the bov is just pulled out of the intake hole , the other side is still connected to the pipe and the intake hole is covered with a filter , i connected the turbo outlet pipe to the soliniod and the waste gate to it on the COM & NO i dont remeber wich 1 is wichs but i knw 4 a fact that its connected right check 100x
You need to explain better, what it sounds to me is your bov is wrong. You need to keep it recirculated (assuming your still maf setup) You stated you put a filter covering the air intake pipe? You cant do that. If you were going to hook up your bov to your intercooler piping you would still need to recirculate it back to the air intake. Cant even leave one side off, your sending bad readings back to your maf sensor.
So your BOV is on your car then? R u saying you relocated it or just disconnected it? So you have a filter on the intake where the BOV was connected, but what is on the BOV then??
I'm having a hard time following you bud...
YOU shouldn't use low octane gas in our cars...in case of emergencies only. But it should start regardless of fuel octane if all else is fine.
so could dat be he probleme i tryed starting it a couple times after let go of the starter it mad a bohh sound and i think it came out from the exhaust or engine ,not loud i berly herd it but sence im in a garage i felt it vibrate
celica2evo (brian) thats not fixing his problem only if he is non maf, if he is maf you cant plug that section up. Not unless there is something new i dont know about. Sounds like his bov is not recirculating and causing a/f probs
If your running low octane your car will have high knock counts, detination and buck really bad.
1 end is connected to the pipe that comes after the intercooler i think and the other end is supose to be connected to the intake but i disconnected that part so instead of shooting the air into the intake it shoots it into the atmosphereto make that woosh sound and it worked i tested it
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
