Stutter at boost
Old Jan 17, 2009 | 06:41 AM
tsidrift1's Avatar
I did a boost leak test this morning. Nothing except the throttle body shaft seal. Now the car wont even start!! What in the hell happened to this car in the last 24 hrs!!
Anthony
Old Jan 17, 2009 | 07:05 AM
tsidrift1's Avatar
I was looking all over the engine bay a few minutes ago. I notice the cam pos. sensor, where the plug is connected is loose. I took it off and looked at it, and it is busted. It looks like one of the metal contacts is broke. I hope this fixes it!
Anthony
Old Jan 17, 2009 | 07:11 AM
Import Junky's Avatar
Wow man sorry to hear your problems. It could have been anyone of them. I was thinking the plugs for sure but now it seems you've found your problem with the sensor. good luck and let us know.
Old Jan 17, 2009 | 07:31 AM
BBoostin's Avatar
Tsidrift1 I've been having the same problem with my car for a week now.!! If I stay out of boost it drives fine.. but when I lay into the throttle it stutters at about 4000rpms...
Old Jan 17, 2009 | 08:00 AM
tsidrift1's Avatar
Yea, thats the way mine is. I just got a new cam pos. sensor. The car starts now. I still have to put in plugs too.
Anthony
Old Jan 17, 2009 | 08:50 AM
tsidrift1's Avatar
OK the car runs much better. I have a vacuum line running straight from the wastegate to the turbo. I can boost 10lbs, but if I try to give it more gas it tries to raise the boost and then stutters. Is this what it does when you are running straight from the wastegate to the turbo?
Anthony
Old Jan 17, 2009 | 02:27 PM
tsidrift1's Avatar
I just got home from work. The car on the way home was a rock solid 12lbs of boost. It didnt try to sputter at all? Oh well, I guess its good then. Ill see if I can hook up the hallman boost controller again tonight and see what happens.
Anthony
Old Jan 17, 2009 | 07:32 PM
TwoFour's Avatar
Hookup your mbc, and if connections are right it should be fine. Mine had the same problem. I hooked it up t'd in between the bov and intake manifold. And make sure to cap and ziptie turbo nipple, and intake nipple.
jmrussell89
Mar 17, 2016 06:34 PM
mitsuEvoIXMR
Jan 27, 2014 08:29 AM
anjapower
22
Apr 27, 2013 04:21 AM
rawburt
10
Aug 2, 2009 06:00 PM
dorsalfin
11
Jun 25, 2007 06:06 AM
Quick Reply: Stutter at boost
