GT3076R Problem?
GT3076R Problem?
Last thursday i had a gt3076r installed with all the mods in my sig...... put it on the dyno and everything was going great when the tuner tryed to turn up the boost and the number goes down Tuner thaught it was a restriction in airflow to the intake manifold we were all scratching our heads on this one any suggestions on the problem?
yeah the turbo is brand spanking new they think my ams intercooler is defective and this thursday were gonna put it on the dyno with a ets intercooler ... but i wanna know evom's opinions .........car holds boost and idles well only making 334 on pump couldnt turn the boost up just made the power go down
Dude, you are going to need to supply way more details than look at my sig and tell me why my car isn't making power.
A short list of info need:
- Manifold and turbo kit.
- What power did your car make before, what has changed since then.
- What dyno, who's dyno, what power does a bone stock evo make on said dyno.
- How much power did you make
- How much boost
- What fuel
- What engine management
That's the short list.
- How much boost
- What fuel
tubular manifold its a road race engineering gt3076 turbo kit info on turbo kit http://www.socalevo.net/index.php?op...&topic=25695.0
stock 8 turbo with bolt ons mande 291 on 91
its a dynapak. roadrace engineering dyno... they usually make around 230-240 stock 8
i made 334 on 91 at 20 lbs
91 oct
stock ecu
91 oct
stock ecu
I highly doubt the AMS intercooler is bad. I have one myself along with a couple of friends. You have a good size turbo for the regular intercooler, maybe not the race one. I don't think you with have high pressure drop. I'm a hands on person, I can't trouble shoot unless the car is in front of me.
There's only really 2 reasons your power would go down when you increased your boost....
1) overly retarded timing
2)really rich or really lean.
What afr and timing are you running?
Have you checked the timing on your cams?
so possibilitys are
do a compression and leakdown test
new spark plugz
retarded timing
running rich or lean? any others u guys got? when i go this thursday i want to run these possibilitys by them!
new spark plugz
retarded timing
