Twin Turbo Evo?
Old Jan 18, 2009, 08:52 PM
AMSevo8man's Avatar
i think peak boost has a twin turbo set up!!!!
Old Jan 18, 2009, 09:18 PM
DaveK's Avatar
Originally Posted by sho669
FP White would be BRUTAL on a 2.3 probably hits full spool at like 1500rpm! J/K maybe 2500 though?
This might be my setup for the rally car. We've got AMS building us a 2.3L with 10:1 compression, and I've got an FP White on the car right now.
I think the big issue wiht the TT setup on the Evo is just packaging constraints, but I'll be the first to admit it'd be cool to see the AMS setup get some more development time.
Dave
Old Jan 18, 2009, 09:31 PM
spdracerut's Avatar
You could try to do something similar to what is available on diesel passenger vehicles:
http://www.honeywell.com/sites/porta...50813231049691
Old Jan 18, 2009, 09:58 PM
adamweldonjohns's Avatar
Sounds like there are both proponents and adversaries to the development of tt tech in the evo. the staged system is very interesting, but sounds almost too complex (with AMS' difficulty in getting the valves to actuate properly), however it seems like there may be room for a smaller tt setup using two similarly-sized turbos. Interesting.
Somebody who's got way too much money ought to hash this one out for us!
Old Jan 19, 2009, 05:26 AM
chuntington101's Avatar
RC Developments in the UK did a twin trubo, but they went bust...:-(
Also has anyone thought about using one of these on a normal manifold but using a Twin Scroll turbo???
http://www.sound-performance.com/p19...duct_info.html
Be nice to see just how fast a 2.3/4 could spool a GT4202RS with one of these on.
Or you could machine the housings out to take a GT47-88!!
Chris.
Old Jan 19, 2009, 12:55 PM
Jim in Tucson's Avatar
[QUOTE=adamweldonjohns;6586021]the staged system is very interesting, but sounds almost too complex [\QUOTE]
Exactly. That's the beauty of a compound turbo set-up. See post number 8.
No mixing valves. No separation valves. Small turbo simply blows into/through the big turbo.
Old Jan 19, 2009, 01:15 PM
tony gibson's Avatar
Dave
Agreed...space under the hood=tight fit and a **** to work on.
Old Jan 19, 2009, 01:24 PM
DaveK's Avatar
If you could construct it using turbos with V-band fittings and dry break oil & water lines, it might not be such a nightmare to work on, but packaging would still be difficult at best. Thinking about the engine bay in my race car, I suppose you could put one turbo in the OEM location, then have the larger one hanging over the transmission where the battery/air inlet piping used to be. It'd still be a tight fit, but I'd bet you could squeeze all the necessary piping in.
Dave
Old Jan 19, 2009, 01:26 PM
SpunEvoIX's Avatar
Originally Posted by SpinninAll4s
Dident AMS just make one in there castrol challenge?
they never ended up doing that twin turbo setup for the challenge because they ran out of time to get the turbos on sequence and timing
Old Jan 19, 2009, 01:46 PM
hacurio1's Avatar
Originally Posted by Joshs EVO
They had a guy put a supercharger on a Evo a while back and made some desent power. I think it was like mid 600's. The car has passed into a few hands though and I'm sure has had more owners since then.
Exactly, instead of a TT setup, what I would love to see is a system similar to what Lancia used is the Delta S4 in the good old WRC group B days. Supercharged for low end, and a big turbo for high-end. Def the best of both worlds, and they were very successful with it in the last days of group B. I do not know the specifics, but was that Lancia a 1.7L? All I remember is it produced 550hp aprox. and the power curve was as perfect as it gets.
http://en.wikipedia.org/wiki/Lancia_Delta_S4
Old Jan 19, 2009, 03:03 PM
Joshs EVO's Avatar
Ya it would be cool to have both but from what I remember about the thread the supercharger took the place of the turbo. It was mounted about the same height maybe little higher than the valve cover.
Old Jan 20, 2009, 12:12 AM
Flyin EVO 2's Avatar
Originally Posted by inco9nito99
Cosmo (his nickname, friend/sponsored by Devo Tuning a couple years back ran a custom twin 16g setup), they ditched it after realizing it's not worth it.
The only problem he had was surge issues. He actually had 2 psi just reving it. I feel that Cosmo and Devo gave up on this idea too soon. They didn't try larger turbine housings, more aggresive cams (they were only on HKS 272's), and an aftermarket intake manifold. I feel this set-up would work great on a 2.3 or 2.4 with MEATY cams. The strokers have better VE down low and can actually put the extra air to work. 2 16G's at 20 psi on 110 octane were coming close to where he had 1 at 28 psi on 116 octane.
Old Jan 20, 2009, 05:42 AM
Chris.
Well i think that looks like a great idea Chris! lol
Old Jan 20, 2009, 08:26 AM
C6C6CH3vo's Avatar
Two twin scrollers might become a dissapointment
Old Sep 3, 2009, 12:35 PM
chemical88's Avatar
this sounds interesting i think i want to do a twin turbo setup on my evo but with 2 stock evo 9 turbos what you guys think?
Quick Reply: Twin Turbo Evo?
