Motor Mount VS Torque Stiffy Damper
Old Jan 19, 2009, 08:14 AM
boostedwrx's Avatar
It's more work to make the Stiffy quiet than it is to just get the motor mounts. I got more noise from my Stiffy even when I had tons of o-rings, plastic washers, dynamat all over the mounts, etc etc. The motor mounts don't make any noise and only cause the steering wheel to vibrate a tad at idle, thats it.
Old Jan 19, 2009, 08:17 AM
Malik_EvoIX's Avatar
Originally Posted by Tsurugi-san
^^^ About the same improvement as you'd get from a good cup of coffee.
i get hyper as hell from drinking coffee
Old Jan 19, 2009, 08:20 AM
evoixmr1818's Avatar
I have the front tranny mount an it was nice when I put it in good shift feel an everything. But after 23000k it seams like stock. It the purple insert I forget the name
Old Jan 19, 2009, 08:21 AM
so after 23000k it "wore out" i didnt know **** like that happens
Old Jan 19, 2009, 08:31 AM
well I won't say wore out but mine don't feel the same as the day I installed.
Old Jan 19, 2009, 09:27 AM
bump
Old Jan 19, 2009, 09:39 AM
Jeovannie's Avatar
you got used to it
Old Jan 19, 2009, 09:48 AM
boostedwrx's Avatar
The Purple is the Powerflex and it's not going to wear out.
Old Jan 19, 2009, 09:54 AM
DS-03evo's Avatar
I have the stiffy in the car now, it rattles and is very annoying. I have a AMS front mount ready to go in. The damper is coming out!!
Old Jan 19, 2009, 10:58 AM
Thoe99's Avatar
Motor mount...do the front and sides if you can, but do not do the rear one. That's the one that will cause all hell to vibrate.
Old Jan 19, 2009, 11:01 AM
Jeovannie's Avatar
the one that will shake your kidneys
LOL
Old Jan 19, 2009, 11:23 AM
Joshs EVO's Avatar
I had Warrtalon tell me that if I just got the dampner then it would wear out faster and not do as good if I put the motor mounts in and then put the Dampner in. So that's what I did. I put the motor mounts in and now my kidneys are where *** is.
Old Jan 19, 2009, 11:44 AM
leecavturbo's Avatar
this blox bushing is having massive reviews and reported as massively improving shifts with much less vibration than the top engine damper types.
some peeps even removing the top dampers and converting to these its so good!!!!!
Old Jan 19, 2009, 11:53 AM
Tnastyevo8's Avatar
+1000000
Have the blox motor mount on my car...AMAZING difference. does all the above.
inexpensive fix
Old Jan 19, 2009, 12:09 PM
Casper.'s Avatar
Originally Posted by Tnastyevo8
+1000000
inexpensive fix
where can i get this, and is this the same as doing the front mount (Agency power).
Quick Reply: Motor Mount VS Torque Stiffy Damper
