what coolant
I'm curious as well. Does the evo use the typical "green" engine coolant that is found over the counter at parts stores. I know GM uses Dexcool and Toyota uses red coolant. I don't know if Mitsubishi uses a different type of coolant or does the basic green coolant compatable.
Bump for you.
Bump for you.
I'm using the search tab, but can someone confirm a question for me...
It seems like my coolant level is like mid Full (---Coolant---) Low
Should I fill some in just incase??? Also should I flush all of it out then put in new coolant or can I buy over the counter Long life Coolant 50/50 can add it in??? Because the coolant in my tank looks blue I don't want to mess up anything if that is something you don't do...
