FP Red Airflow Logs Wanted
I have heard what the FP Red is supposed to flow ~57lbs/min - 60lbs/min, but has anyone actually logged the airflow of the Red? If anyone has, I would be interested in seeing the results and what boost they were achieved at. A general mods list w/ any turbo porting would be helpful as well.
Thanks
Edit:
I have taken the data from Bryan @ GST to get rough estimates on airflow based on the items in his logs (see below). It gives a ballpark on the flow of the turbo's compared, and more important is to see the delta between the different options out there.
Here's what I gathered from those graphs:
Stock IX = 1700Hz
Stock IX @ 28psi = 1900 Hz
Green= ~2010 Hz (not sure on psi)
BBK= ~2190Hz (not sure on psi)
Red @ 24.5psi = ~2290Hz
Peak Load = 285 @ 5200rpm
Peak Load lb/min = 34.36
Load @ peak Hz= 255
lb/min @ Peak Hz = 44.34
Red @29psi = 2300Hz @ 7500rpm
Peak Load = 340 @ 4000rpm
Peak Load lb/min = 31.53
Load @ peak Hz= 260
lb/min @ Peak Hz = 45.21
Red @28psi = 2300Hz @ 7500rpm
Peak Load = 320 @ 4000rpm
Peak Load lb/min = 29.68
Load @ peak Hz= 270
lb/min @ Peak Hz = 46.95
Red @ 31psi = ~2600Hz @ 7500rpm (what sort of porting?)
Peak Load = 340 @ 4500rpm
Peak Load lb/min = 35.47
Load @ peak Hz= 295
lb/min @ Peak Hz = 51.3
HTA35R @ 33psi= ~3180Hz @ 7500rpm
Peak Load = 360 @ 4500rpm
Peak Load lb/min = 37.56
Load @ peak Hz= 335
lb/min @ Peak Hz = 58.25
I found the following info. for roughly converting Hz to lb/min. In my searching it also stated you should have IAT & Baro as Eric stated above, but those are used to calculate overall load. https://www.evolutionm.net/forums/ec...low-lb-hr.html
Load= (roughly) hz/rpm*852
g/rev= load/95
lbs min= g/rev*rpm/454
Thanks
Edit:
Stock IX = 1700Hz
Load @ peak Hz= 255
Load @ peak Hz= 260
Load @ peak Hz= 270
Load @ peak Hz= 295
Load @ peak Hz= 335
g/rev= load/95
as well.
Thanks
as well.
Thanks
BBK vs Green:
Stock turbo, stock 9 (no mods) with factory tune, custom tune with stock boost, custom tune with stock boost with solenoid side pill out:
Evo 9 turbo at 28psi:
yes Maf Hz, sorry.
Maybe Bryan has the load logs. Load is already baro and temp corrected and can more easily be converted to a mass airflow. Load is really a mass airflow/rev.
Eric
I derived an equation to get close a while back in the ECUFlash forum. but you also need baro and intake temps.
Eric
Eric
I used to log lb/min as well but something messed up with the equation in evoscan and I have been too lazy to fix it.
Here we go:
Evo 8, 91oct, 24.5 psi peak
Cams, TBE, fmic, ECU-boost
356whp on our dyno
Evo 9, 91+meth, 29psi peak
Cams, TBE, fmic, ECU-boost, porting
400whp on our dyno
Evo 9, 110oct, 28psi peak
425whp on our dyno
Evo 8, 110oct, 31psi peak
450whp on our dyno
Evo 8, E85, 33psi peak, Buschur HTA35R (FP housing)
Cams, TBE, fmic, Blitz EBC, porting, built 2.3L, cosworth head
558whp on our dyno
356whp on our dyno
400whp on our dyno
425whp on our dyno
450whp on our dyno
558whp on our dyno
Interesting, here's what I gather from those graphs:
Stock IX = 1700Hz
Load @ peak Hz= 255
Load @ peak Hz= 260
Load @ peak Hz= 270
Load @ peak Hz= 295
Load @ peak Hz= 335
I found the following info. for roughly converting Hz to lb/min; let me know if I'm way off base. In my searching it also stated you should have IAT & Baro as Eric stated above, but those are used to calculate overall load. https://www.evolutionm.net/forums/ec...low-lb-hr.html
g/rev= load/95
Stock IX = 1700Hz
Load @ peak Hz= 255
Load @ peak Hz= 260
Load @ peak Hz= 270
Load @ peak Hz= 295
Load @ peak Hz= 335
g/rev= load/95
I think your calculations above for lb/min are a little off. For a rough estimation, you have to use the load at the RPM being measured. You are using the peak load but using 7500 RPM.
For example, the FP Red graph on 110 octane shows a load of about 295 at 7500 RPM:
approx lb/min = 295/95*7500/454= 51.3 lb/min
The HTA35R was about 335 load at 7500 RPM:
=335/95*7500/454 = 58.3 lb/min
Granted, you have to understand this an approximation that carries a lot of assumptions with it, but it can get you in the ballpark.
Bryan,
If you get a chance, can you post the MAF Hz against load for the BBK full's you have done? I would just like to crunch those to give me a ballpark for that turbo at a certain PSI. (Thanks for all the graphs you have provided already)
