EBC holds same BOOST EVERY GEAR ?
Hey Guys I am just wondering if BOOST controllers are suppose to hold the SAME BOOST every single gear. Because me e01 will not hold the same boost for 1st and 3rd gear. If i set my first gear to be 17psi then my 3rd 4th gear will be 19 psi and if I set first gear to 19 3rd 4th gear will be 21 22 . Is this normal for Boost controllers ??? I never had a turbo car and this is my first time using boost controller.
Re: EBC holds same BOOST EVERY GEAR ?
Set your peak boost in 4th.
Also don't forget that a turbo runs best on it's peak effcenty So you will have a peak boost that will tapper off.
Eric
So its normal to have Lower Boost on 1st 2nd gear and higher boost on 3rd 4th 5th gear. Because I keep hearing people saying 19 psi to red in every gear and I just dont understand how is that possible.
It becomes possible with a full turbo back exhaust.
Personally speaking, I dont like setting it up to taper at all - I prefer it hit peak boost and remain there to redline, but its all about different tuning methodologies, the type of gas you get, etc etc.
Eric
j8
Jun 15, 2005 12:47 AM
TonyG
Apr 10, 2004 07:24 PM
