PCV and Breather Blowby in oil catch cans
Old Jan 25, 2009 | 02:02 AM
Johnboy1065's Avatar
I have an oil catch can on both my PCV valve and on the breather on the valve cover.
lately I've been getting quite a bit of blowby and it's accumulated pretty quickly
Most of the blowby comes from the breather on the valve cover - could this mean bad valve seals?
Only a little bit comes from the PCV valve itself - but still enough to concern me.
I've heard that you will get more blowby during the winter time because the cold air allows the vapors to condense which will let you catch more liquid.
the blowby looks like chocolate milk lol, and smells like crap.
is the best way to check this just to do a compression test or leakdown test?
please let me know ya'lls opinions
thanks,
John
BTW: nothing drastic as in the oil dipstick popping out has happened (BUT I havent been in boost at all lately since my car is untuned for the new stuff on it)
Old Jan 25, 2009 | 11:03 AM
bump for opinions please!
Old Jan 25, 2009 | 11:18 AM
Evo_Someday's Avatar
In your case - yeah - maybe it is just condensation evaporating out. Hope for the best.
I don't use catch cans so I can't offer personal experience on this one but... if it were me - I would not worry about it right now. Especialy since it seems to have started once the weather got cold. Just keep an eye on the oil level and see if it gets better once the weather warms up. That's what I would do.
Old Jan 25, 2009 | 11:20 AM
Ph3n1x's Avatar
You can't say you have bad seals without doing a compression and leakdown test.
Otherwise i would say that you may have a defective PCV or clogged line.
Try using MAPerformance Krank Vents. They solved all my issues.
Old Jan 25, 2009 | 11:32 AM
what is a crank vent? it just take the place of the PCV valve?
Old Jan 25, 2009 | 12:05 PM
hey ya'll I'm going to do a compression test later when my friend gets off work...it's a lot easier to do a compression test when ya have 2 people.
Old Jan 25, 2009 | 01:12 PM
BTW I have never replaced the PCV valve in the 70000 miles since I've had the car.
also, the way my oil catch can is setup, it goes from the pcv valve - to the catch can - and to the ground.
breather - to catch can - to the ground
does the PCV valve require vaccum to work properly?
Old Jan 25, 2009 | 03:14 PM
Oracle1's Avatar
I had this recently, I found by doing a oil change including engine flush and empting the CC, in my case resolved this.
I cannot offer a reasonable explanation but since this blowby has reduced/eliminated.
Old Jan 25, 2009 | 03:40 PM
4G63 T's Avatar
what sort of issues did it solve?
thx.
Old Jan 25, 2009 | 04:57 PM
Ok ya'll I tested compression with the motor warm and the gas pedal to the floor like your supposed too here are the results:
cylinder 1: 170
cylinder 2: 165
cylinder 3: 165
cylinder 4: 170
so I'm thinking as far as compression that I'm good. so I'm guessing the rings are fine. What do ya'll think?
Old Jan 25, 2009 | 05:22 PM
Oracle1's Avatar
I have read that oil can get clogged up in the turbo lines thus causing this too.
Old Jan 30, 2009 | 07:12 AM
Davo's Avatar
my breather is dry whereas pcv is like an oil well
Old Feb 9, 2009 | 07:24 AM
mindoftw's Avatar
Yah i checked my breather on my car and it was soaked, i will probably need to make a catch can for it, i am having the same probablmy with the OP so i am hoping it is just the cold weather, i myself had chocolate milk on my breather lol.
anthonyrb98
Jul 10, 2011 10:38 PM
smokedmustang
65
Nov 19, 2007 09:39 AM
steelcityevo8
Nov 1, 2007 08:21 PM
BluEVOIX
Apr 4, 2007 12:52 AM
VTEC Killer
13
Mar 14, 2005 08:47 PM
Quick Reply: PCV and Breather Blowby in oil catch cans
