digital boost gauge sensor problem
I want to buy the dynotune digital boost gauge but the sensor has 1/8npt threads. I currently have a mechanical gauge and its tapped into the line from the intake mani and FPR. My question is there a way possible to use the same point with a sensor like this or will i have to drill and tap into the intake manifold?
http://www.dynotunenitrous.com/store...p?idproduct=53
Would one of these adapters work?
http://www.veneersupplies.com/images/brassfitting2.jpg
As long as that sensor requires a vacuum reading, I wouldn't see why using the barb fitting wouldn't work. Also for the price of that gauge, you could get a Defi or a STRI gauge which will match the factory gauge cluster and looks a lot nicer IMO but I'm not telling you what to do because if you like it, that's all that matters.
i think that should work also i had to do that with my old boost gauge... but then i got a defi which comes like that and i love the defi its so nice and matches perfect
