Reverse Sensor Location?
My reverse lights are out- both of them.
1. I pulled the tail lights off, and checked the bulbs. They are both good.
2. I supplied power to the bulb using a power source and it lit up.
3. I Checked for power at the bulb harness and there was none.
4. I Checked all fuses under the hood and in the engine bay using a test light. = All good.
I am not sure how long I have not had reverse lights, but I recently went through some deep snow and mud. On my subaru the reverse sensor was located on the transmission down low. So I suspect I may have damaged the sensor or wiring. However, when I looked down there on my evo 9, I am unable to locate the sensor.
Does anyone know where the reverse sensor is located so that I may test it?
Thanks,
unsung
Thanks,
unsung
