From HTA35R to Full Race Borg Warner Setup
Old Jan 29, 2009, 10:50 AM
  #31
Magnumpsi's Avatar
John I will send you that other plot I totally spaced it.
Let me dig it up.
Mitch
Old Jan 29, 2009, 03:37 PM
  #32
Magnumpsi's Avatar
The car is going on the dyno right now. I should have results in the next couple hours.
Mitch
Old Jan 29, 2009, 04:52 PM
  #33
gsrboi80's Avatar
Your killing us. You know that right. Waited on 2 results today. The first cars clutch slipped at 14psi the thread said so this car better perform.
I need my fix.
Old Jan 29, 2009, 07:34 PM
  #34
TurboRSX04's Avatar
where the results at? =)
Old Jan 29, 2009, 07:39 PM
  #35
Magnumpsi's Avatar
I got some initial results.
Started tuning so far the car sits at 460 at 24psi. I still have a lot of tuning left and it will resume in the morning.
As it sits I am making 21psi a little under 5000 RPM.
Dyno sheets, videos, and pics tomorrow.
Mitch
Old Jan 29, 2009, 07:44 PM
  #36
thatsMR2u's Avatar
cant wait to see results
Old Jan 29, 2009, 07:52 PM
  #37
less10's Avatar
This is some nice info. What cams, still a 2.3 right?
Old Jan 29, 2009, 09:50 PM
  #38
boostinmarc4's Avatar
Nice initial numbers
Old Jan 29, 2009, 09:59 PM
  #39
AWD Motorsports's Avatar
Originally Posted by Joshs EVO
I think it was AL or Mike @ AWD said he won't use the BW cause after 50 lbs them seem to blow up. But then again who would be running 50 lbs
Even at 45psi i hurt one of the BW units.. They are only 270 degree thrust bearing and are not as durable as a 360thrust BB unit..
Mike
Old Jan 30, 2009, 09:34 AM
  #40
Magnumpsi's Avatar
490hp is where I left it.
We are going to swap housings today and see how it does. The car needs the bigger 1.0 housing as the .91 is a little too restrictive at the top end of the runs.
I will scan a dyno sheet here shortly.
Mitch
Old Jan 30, 2009, 10:26 AM
  #41
DS-03evo's Avatar
Are you running it on straight pump, or pump+meth?
Old Jan 30, 2009, 12:05 PM
  #42
Magnumpsi's Avatar
Pump +meth.
Mitch
Old Jan 30, 2009, 12:25 PM
  #43
evoPirate's Avatar
Mike
Still....who is even going to be running 45psi on their cars all the time? Unless its a purpose built track monster, it seems most guys run day to day well under 40psi even.
Old Jan 30, 2009, 12:46 PM
  #44
gsrboi80's Avatar
Where's the graph I want to see the spool
We are PITA's aren't we
Old Jan 30, 2009, 12:49 PM
  #45
Magnumpsi's Avatar
Not at all lol. I was as curious as all of you are.
They will be up in just a minute.
Mitch
Quick Reply: From HTA35R to Full Race Borg Warner Setup
