Help Bov sound adjustment???
I just got my turbo XS rfl bov installed today and i found that the sound that it makes is different from what I have heard on other cars. Right now it sounds like a long flutter. I dont like that sound, i was more of a woosh. please help
thanks
F.B.
thanks
F.B.
I am working on the same issue, I think the spring is to tight. I am running the Type H and I am using no spacers and getting a small amount of flutter at around 5psi or lower. Do you have it constantly?
With a correct tune you can run VTA on MAF with no problem. Make sure your vac line running to the BOV is not pinched. Also might want to make a dedicated line for the bov vac source with no t's and make sure its ID is plenty. If your getting some surge, first check vac line as i mentioned above, then possibly try a lighter spring. Some surge at low PSI is no biggie. If all else fails, try a better bov. Haven't heard that many great stories with the turboxs.
