car won't idle :(
car won't idle :(
I was driving along today, when I came to a stop and my engine died. Ever since, it idles at around 400 - 500 RPM and conks out after a few seconds. I do have an exhaust leak in my downpipe, but could this be a cause for my car not idling? tomorrow i'll check antifreeze and look for a vacuum line detached, but i figured i'd bring it to the pros quick.. anyone else have any ideas?
thank you!!
thank you!!
i talked to a friend of mine who is a mechanic and he's guessing the throttle body is just gunked up. he also said most vacuum leaks will make the car idle higher. i checked as many hoses as i could see, i didn't see anything that looked off.
anyone know how to do the boost leak test?
ok, so i turned that phillips screw on the backside of the throttle body.. out about 3 turns and the idle went back up to 900 RPM. i'm sure that's just masking the problem, plus this morning when i started my car it wouldn't stay running until it was warm. at least once it's warm it stays running at stops now.
i think the problem is either..
boost leak or gunky throttle body. i'm hopefully having my throttle body cleaned this week.
