Throttle Body Coolant Leak?
Trying to chase down missing coolant and occasional green puddles, I refilled the overflow, put the front in the air and started looking. Found a green puddle around the top of the hose at the TB. I wiped it clean and attached a picture after I'd done so.
I found a puddle on top of the trans, behind the motor and took a pic.
Are there any other leaks that could puddle back there? I just can't find any other leaks so far, or evidence of dripping/splashing/squirting coolant other than that location so far.
Thanks!
Thanks!
The 2 lines that goto the throttle body seem to get very spongy after time and cause leaks. I had one of those lines split on me a few months back. I couldn't believe how spongy they were when I replaced them. Same goes for the 2 coolant lines for the turbo, those tend to get spongy after time as well so I would check those too.
^^I just went to my local autoparts store and got some 3/8" or 1/2" fuel line, it seems to be a bit tougher and thicker then the OEM lines and will handle allot more then the spongy crap.
Drove for a while tonight. The screw-style hose clamp is holding for now. I'll give it more work tomorrow and make sure the radiator is topped off.
Fuel line doesn't sound like a bad option. I'd just rather replace every damn coolant line at once with the same, quality material - silicone or otherwise. She's got just over 70,000 miles on her...
When you stop and think about the radiant heat generated by the turbocharger's turbine housing, as well as the exhaust manifold, in addition to the heat transfered to the center housing, then you would discard any possibility of rubber hoses existing in such an infernal environment.
![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
1 Post
Naw, think again! The coolant feed and the coolant return lines to and from the turbo on the Evos are both steel hardlines. I guess that you've never done a turbo swap on one of these cars before.
When you stop and think about the radiant heat generated by the turbocharger's turbine housing, as well as the exhaust manifold, in addition to the heat transfered to the center housing, then you would discard any possibility of rubber hoses existing in such an infernal environment.![Thumbs Down](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsdown.gif)
Slow down there Sparky!
![Throttle Body Coolant Leak?-resized-turbo-coolant-hoses.jpg](https://www.evolutionm.net/forums/attachments/evo-engine-turbo-drivetrain/128713d1461625051t-throttle-body-coolant-leak-resized-turbo-coolant-hoses.jpg)
The lines directly attached to the turbo are hard steel lines however they then connect to soft rubber lines that go to the side of the block over the transmission. See the connections circled in the picture.
Josh
![US Flag](https://www.evolutionm.net/forums/images/smilies/smillie_flag.gif)
What is the purpose of the coolant going to the throttle body? If its anything like the LS1 setup, its for cold start driveability, I believe. This has to affect performance slightly though, since the throttle body is being heated up. I would go out on a limb saying we would be able to just not run these two lines and the car would be fine.
This is all assuming that its purpose is to heat the throttle body for cold driveability, and not another purpose though. Thoughts?
