Buschur Racing begins "Project White" a wicked street build.
#32
Thanks David. I also pmed you. Also, great built! Its going to be a beast!!
Why did you chose to go with a different stroker setup than your typical 2.3 off of the shelf? Is it because you have more money to play with in this build or just want to try a different combination?
#35
BTW, I always love to see engines being built
#36
That is a very low power loss with a cat. I'd be interested in trying one of them if they flow that good. My guess is though with the red, the 2.3, the E85 and the power this is going to make my HP/TQ guess is going to not be far off. I could certainly be wrong though. Shoot me a PM with a price on a cat, please.
#37
We would love to be a part of this project Dave.
We are confident that you'll be impressed with our cat should you decide to use one.
#38
We use Mitsubishi stock head gaskets all the time here, they will hold 60 psi of boost without issue. On this car I am going to try one of the Cosworth gaskets because we bought a few to look at after an article I read on them by Eric Hsu.
The deck surface is surface cut to the smoothest possible finish we can get with the cutter that is used. That is the best answer I can give. It is not ground, it is cut.
Article for anyone that wants to read it.
#40
Nobody talks about it because most of them don't set it up right and the squirters end up broken off and in the oil pan It make me laugh to see the hack jobs I've seen on the squirters. Like I said, I do not want to get into the specs/clearances of the build. I will simply say I try to set it up so the squirter is between the crank counter weight and the piston skirt. You have to clear them both.
#41
Thanks for posting that link of the head gasket testing. I've known Eric a long time, he's been around. Good dude.
Now that I went back and read it, it's funny he talks about the poor sealing gasket as I have found they suck too.
The stock one, as I said, has worked out excellent even at very high boost. Just thought I'd give the Cosworth a try.
We also stock them.
BTW, something I did notice. IF you are doing a .040 bore block then do not use the Cosworth, it has a slightly smaller bore diameter that does get into the bore some. The stock gasket will clear a .040 overbore.
We also stock them.
