Death Wine----this time not the front!!
Old Feb 10, 2009, 12:24 AM
dxbevo9's Avatar
alright..so i bought my RS with a bad death wine in the front...figured its the regular death wine...changed my front diff. to a very very healthy/almost new front diff...and unfortunately the biatch wine is still there..however now the noise is clearly coming from the rear...
questions:
-is it usual for the rear diff to wine?
-since i have a JDM RS (ie) non AYC...will any USDM non AYC rear diff work in my car?
-finally, is there any chance that it is not from the rear diff? (ie could be the drive shaft,axles or any other thing)?
thanks gentlemen in advance..any kind of input is greatly appreciated.
Respect,
Moosa
Old Feb 10, 2009, 12:41 AM
Toxin's Avatar
Sounds often travel around the chassis and from the inside of the car, it's often impossible to locate where the whine is coming from. Shoot it up on a lift and try to replicate the whine there and figure out from the outside where it's coming from. That's the easiest way to not try and replace something that doesn't work again.
About the RS diff - yes, it should fit from any non-ayc car. From what mechanics told me atleast.
Old Feb 10, 2009, 12:48 AM
Evolution7GSR's Avatar
are you sure this death whine is not from your transfer case?
Old Feb 10, 2009, 12:56 AM
RevMoto's Avatar
I have the same thing at the moment. It definitely sounds like it is coming from the back but a whine is hard to detect. I bought some amsoil to do a flush and see if that will quiet it down. I would much rather change the rear diff than the transfercase.
Old Feb 10, 2009, 01:23 AM
dxbevo9's Avatar
excuse my ignorance..but what do you guys mean when you say transfer case? you dont happen to mean gear box do you?
reason i am asking is because we (in this part of the world) usually refer to the transfer case as front diff.
thanks for all the inputs
Old Feb 10, 2009, 02:17 AM
dxbevo9's Avatar
alright...did a quick research..and i was correct..what i have replaced is my transfer case
so i am assuming my only next option is a rear diff no?
Old Feb 10, 2009, 03:14 AM
Excalibur's Avatar
How do you replicate something like that on a lift?
Old Feb 10, 2009, 04:28 AM
Toxin's Avatar
Lift the car and put it in gear... Put on a helmet and take a parachute with you aswell...
If something whines because it's F'ed up already, it's possible it'll whine with no load on the wheels too - for example, a transfer case whine when it gets loud can be heard from almost anywhere in the car if you're sitting in the car. Once you get out, you'll hear exactly where the noise is coming from. Or you could do like Tom Cruise and do it hanging down from the axles and driving around.
Old Feb 10, 2009, 04:40 AM
abazaba410's Avatar
damn i have that whine too when i drive... i hope its not my t case
Old Feb 10, 2009, 11:22 AM
04EVOCHICK's Avatar
Okay guys so I had the same problem with my 06 MR and everybody was thinking that it had to be the Transfer case because it was whining really bad on decel and when it was in reverse made awful clanking noises. The problem was not the TC at all it was the rear differential. We swapped out the rear diff and since then havent had any whining at all. Hope this helps.
Old Feb 10, 2009, 03:12 PM
justa4banger's Avatar
try changing the fluid...when i first got my car it had 50k miles on it and the rear diff would whine loud.... than i changed the fluid and it stopped whining...
Old Feb 10, 2009, 05:28 PM
abazaba410's Avatar
im at 78k n just changed mine at 75k
Old Feb 10, 2009, 07:15 PM
EvolNinja's Avatar
What's with the whining. Mine does it too like a few week ago. Like someone in here said, I should change my fluid again on the T-Case and the rear diff to see if the damn whining stop.
Old Feb 12, 2009, 01:47 AM
dxbevo9's Avatar
apparently i need a new diff
Old Feb 12, 2009, 08:55 AM
PATRICK B.'s Avatar
How did you come to that conclusion?
I know you said you changed the center diff but what about the ring/pinion gears in the TC?
I had a terrible whine on decel and started to have a whine all the time......ended up sending the TC to Shep and he had to replace the ring&pinion.
I had initially thought i had a whine coming from the rear end as well but i guess it was transfered through the d/s back to the rear.
I get it back today and will throw it in this weekend so i'll update the other thread that's going around about decel TC noise.
Not sure if this helps at all but another place to take a look.
Quick Reply: Death Wine----this time not the front!!
