EVO hesitation, shutter HELP!!!!
I have a 2003 evo that I just got and come to find that when you put the pedal to the floor(full throttle) when the rpms hit 3 to 3500 seems like the engine just cuts out and just shutters to beat hell, falls on its face. it doesn't normaly do it in 1st gear but 2nd and 3rd every time. any ideas????
thought so to when the solenoid has voltage applied to it it is then open venting waste gate press line. this always has 12v applied to it when key on and never cycles to 0v. so i replaced the ecu and press sensor (map) checked wiring to and from ok.
when i replaced timming belt i did notice that when i turned the crank to line up the cams by hand there would be alot of belt slack on the timming belt inbetween the camshafts. but whenn i run the engine then shut it off the belt is tight. could this be a timming issue??? I reall y appreciate everyone help.
hey guys haha got it turns out it was a coil never knew it would have been just a coil misifiring under load. replaced the coils and don't have the hesitation anymore. I was thinking if It was that then i should have got a check engine light on. but i hear that these don"t monitor misfire ubove a set rpm??? who knew!!!!!! lots of money wasted but nevertheless thanks for the help.
FS[Pacific NW]: 9sec9 Carbon fiber bumper shutters
reactionevo8
Jul 12, 2017 10:22 PM
Whitewind
29
Sep 30, 2009 06:25 PM
psphinx81
For Sale - Cars For Sale
Nov 29, 2007 10:35 AM
avengerhed
Sep 10, 2005 10:33 AM
