Car sounds like a subaru :'(
Old Sep 11, 2009, 01:16 PM
  #61
dafunk630's Avatar
Originally Posted by fvaldes
Mine sounded like that and it turned out to be a rod bearing that slipped and ended up on top of the upper one. Good luck.
Happened to me 3 times. All 3 times were built by TTR, I guess thats the outcome when you let TTR touch your car or at least the motor.
Old Sep 11, 2009, 08:03 PM
  #62
riceclown's Avatar
my problem was the fuel injector relay which is located on the firewall next to the abs module. it was holding water on top of it unitl the connectors completely rusted thru and broke off. i was getting different voltage readings especially at cylinder 3 which is the one that was misfiring.
BTW, i traced the wire back to the broken connector that corresponded with 3rd fuel injector
try that
Old Sep 17, 2009, 03:09 PM
  #63
maxims4g63's Avatar
Originally Posted by Clutchdc5
your having a cylinder missfire or not sparking up, check your plugs QUICK!
agreed. check ignition system. as for high temps, start with the obvious: hoses, thermostat, or radiator.
hope ur back up and running soon!
Old Sep 17, 2009, 08:16 PM
  #64
ctninea's Avatar
what about the injector resistor pack?
Old Jun 15, 2010, 12:44 PM
  #65
NJ_evoIXgsr's Avatar
this just hit me today. supposedly the resistor pack went bad. ran fine then out of NOWHERE. got the surbaru sound. definitely something wrong if that happens.
Old Jun 15, 2010, 02:09 PM
  #66
evo<3's Avatar
this thread is very old dood lol.... but honestly to anyone that has any weird noises coming form there car specially the motor area i suggest you take the car to get checked out and dont do what i did.... wait to figure it out...eventually my crank just decides to crack... lol
Jbundrick
Jul 18, 2017 02:17 AM
BoostnJimbo
Apr 10, 2017 06:37 PM
Seth_Horton92
Feb 9, 2017 07:13 AM
loco21
Oct 22, 2012 08:50 AM
BriK
32
Aug 27, 2012 06:30 AM
Quick Reply: Car sounds like a subaru :'(
