no idea what to do
Old Feb 24, 2009, 09:22 AM
d0nald's Avatar
umm without being in teh car, id proabbly ahve to say it engages about half way up?
i can check on my lunch break
i didnt think i drove it wrong, i mean u ise little to none of the gas pedal when im starting off in first, the only time that im "beating" on it is from a roll, on the highway if i step on it and hold it down, my rpms start to go up, then they jump up and come back down a little. im tempted to make a video so that you all understand whats happening.
Old Feb 24, 2009, 10:36 AM
X_Evo's Avatar
Your clutch is slipping. No need to make a video. It will get worse and worse as time goes on. You need to replace it.
Old Feb 24, 2009, 10:48 AM
AlwaysinBoost's Avatar
yep, thats a slipping clutch.
did you break your clutch in for a thousand or so street miles before you started doing highway pulls with it?
Old Feb 24, 2009, 11:22 AM
PSG Evo's Avatar
def make the adjustment first and then see if that improves things; do not prolong it anymore.
chances are if you haven't been riding the slipping clutch for too long, you still have a lil hope.
Old Feb 24, 2009, 04:34 PM
d0nald's Avatar
went to the dealer
and they he (the guy that works on my car) is going to say that theres a defect in the pressure plate. and that hes gonna try to get it warrantied. so it looks like i may be getting a new stock clutch for free. so i guess thats a good deal for now. untill i can save up and get like an exedy twin plate or somthing lke that. i plan on doing injectors and cams and all that fun stuff in the future
Old Feb 24, 2009, 04:45 PM
huevosrancheros's Avatar
It did sound like a defective clutch, your stock clutch should be able to hold onto those ponies.
As far as ACT goes I have heard mostly bad things about them. Poor engagement, poor wear. Who knows I haven't personally owned and when it comes down to replacing mine I'm just going for the exedy stage 1 clutch. Twin disk is just too expensive for me and my car sees more street driving than anything.
When it comes down to chooseing your clutch just think about realiablilty, is it really practical and how does it behave on the street???
Good luck w/ your clutch problem.
Do check out the Evomoto.com website though on how to adjust your clutch. Awsome DIY!
Old Feb 24, 2009, 08:15 PM
PSG Evo's Avatar
that's cool. Good luck.
If the pressure plate is the problem, you'll visually see bent fingers (springs).
Old Feb 24, 2009, 08:16 PM
Duh Panda's Avatar
exedy twin or quartermaster... do it right the first time.... errr second
Old Feb 25, 2009, 05:12 AM
d0nald's Avatar
haha more like third!
im just awaiting the phone call. and when/if i do get it, and it is warrantied, ill let everyone know. hopefully ill have that new clutch by friday!
then im not going to drive it hard, at all. and save up every week for that exedy twin! sound like a good idea?
although he was telling me how a clutch was a bad idea, cause you want the clutch to be the weakest link, because its waaay more expensive to fix everything else when it breaks. and he said no doubt if i get a new clutch i WILL blow up my transmission...
Old Feb 25, 2009, 07:57 AM
PSG Evo's Avatar
blowing up transmission is the results of the driver abusing the clutch pedal in the first place. they're most likely going to take your transmission off, look at the flywheel surface to see if there's irregular heat patterns.
Old Feb 25, 2009, 08:11 AM
d0nald's Avatar
well hes warrantying it without my car even there
hes going to tell the calim people that theres a defective pressure plate.
and im still waiting on his call to give me the word, or not.
i dont know what you mean by abusing the clutch, besides launching.
Old Feb 25, 2009, 09:06 AM
PSG Evo's Avatar
lol, there's a long list of 'em
- riding the clutch
- using the clutch to induce drift (called clutch kick) while rallying
- starting car in higher gears from a stop
- improper downshift rev match
silly things people do
Old Feb 25, 2009, 09:40 AM
hotrod2448's Avatar
I really don't think you need to bother with a twin disk clutch. Even with cams the stock clutch should be fine as long as you aren't launching the car and know how to operate a clutch properly which you say you aren't and do know how to do.
Old Feb 25, 2009, 10:08 AM
crazyitr's Avatar
Stick to a single disk Exedy. Much easier on your drivetrain. Talk any tranny builder that's the advice they'll give you.
Old Feb 25, 2009, 10:09 AM
l EVO n's Avatar
Originally Posted by d0nald
Perrin FMIC
Injen upper and lower intercooler piping
Medallion DP/exhaust
Injen intake
MBC
Hyper Voltage System
Bigger Compressor housing
and its tuned
yeah im looking for deals on an exedy twin disk
im just looking for the right price!
danmm so u got +400bhp just with these mods?
Quick Reply: no idea what to do
