Throttle Hang?
Throttle Hang?
hey guys,
ive noticed that at higher RPM's(anywhere above 5000 rpm's) when I let go of the gas, my RPM's keep climbing,maybe a good 300rpm's .Someone said it was caused my something called a idle control valve(not sure if thats what he said)?? I was watching videos on youtube and noticed some evo's dont do that.I've also heard that it was normal.
Heres a quick little video of mine I took.
http://www.youtube.com/watch?v=Ni0pJ...eature=channel
you can here when I let go of throttle and here the RPM's jump up.Maybe its because im untuned at the moment?
my mods list is
full turboback less o2 housing
evo ix turbo
walbro fuelpump
K&N filter with MAF adapter stock intake pipe
forge MBC
ACT clutch and flywheel
thanks for any info!
pj
my mods list is
evo ix turbo
walbro fuelpump
forge MBC
pj
are you sure they arent jumping up because you are pushing in the clutch before letting off the gas? If the RPMS are just staying high then its normal on evos. I asked about this a couple of months ago. Apparently there has been a ton of threads on this. Just search the title of your thread "throttle hang"
Adjust your driving style My car did this when I first got it too....somehow it magically went away with more practice! You may also consider just going to tephra v5 and doing NLTS, that helps with this too
thanks for the input guys!
accullay,its not my driving style.How do I know?because when i bring my RPM's up,and let go of throttle,without pushing the clutch in,it still goes up.
You need to scale down the idel stepper table using ECUflash. I had the same problem, actually much worse. But is gone now. Only down side is no cold start, you have to hold the pedal to get the revs up during a cold start.
ouch really?I guess i'd have to take it to finally get tuned then.i'm just too light on cash.
is it something I should be concerned about?I mean,I dont drive the car hard like that too often.
Well for me it was a problem, because at the track during braking before corner entry i was braking against the throttle and cooking my brakes. Not to mention i didn't get the engine braking i was after. So i guess it depends on you. It bothered the **** outta me though.
totally understand!when im auto-x i can feel it a tad bit,too.So if I get the idle stepper adjusted,then I'd have to sit there while it warms up?
You have to sit there holding it at ~2k or what ever you want till it warms up. Or else it'll die. But i have 272's so maybe a different out come for you
Philisdiller
Oct 4, 2015 09:49 PM
pjb00stin
Dec 30, 2008 12:53 PM
93civEJ1
Oct 17, 2004 07:51 AM
