rebuild my clutch master cylinder?
Well for some reason my clutch pedal started to move engagement points so I decided to bleed and adjust it. Now it will be where it needs to be for a little while, then throughout the day it will slowly move closer to the floor to where its unable to disengage the clutch. When it does that all I have to do is lift the pedal back up with my foot, but then it engages the clutch way off the floor and slowly moves back down again. Could this be from the o rings on the master cylinder leaking or what? is there a rebuild kit for that cylinder?
Usually the slave(clutch) cylinder has a broken seal. Check for leakage under the carpet as well as in the bay. If it were your master cylinder, you'd have brake problems as well. Hope this helps
the brake and clutch use separate master cylinders... what does russelm have that would help?
Yes i understand that. Check to make sure that none of the seals are cracked and leaking(floor board under the carpet). Otherwise, there is air in the line. I've gone through it a couple times now.
Fireescape
Jul 4, 2016 11:18 PM
Llew
Jan 18, 2016 01:00 PM
DuBBzEvo27
Jun 16, 2014 09:58 PM
KlanjacOFF
10
May 29, 2011 04:19 PM
