Running richer and richer...
Old Mar 3, 2009, 03:37 PM
Evo H8's Avatar
Hi guys,
Its another "help me fix my Evo" thread. Seems like there have been alot of these lately.
Anyways, here are the mods I am working with:
Stock block
Ported FP Red Turbo
Kelford 272 cams w/spring & retainers
EPM 02 Dump
Perrin FMIC & RMR piping
RMR Intake w/Perrin filter
Buschur Turbo-back exhaust
Buschur ported/coated stock exhaust manifold
PTE 1200CC injectors / Buschur dual fuel pumps
Tuned on stock ECU @ 28 - 29psi. 440WHP on a mustang dyno.
Problem:
Over time my car has been running richer and richer, particularly inbetween high rpm shifts, at part throttle under normal driving, and now even at idle. By rich, I mean it falls off my gauges scale below 10.0 AFR. When it does this, the car bucks violently back and forth.... Its almost like a backfire or something. My gas mileage has been cut in half - I'm getting 10mpg under normal driving, no WOT.
I dont think it is the tune, as the car ran fine when I first got it back but deteriorated over time. Could it be bad/blown coils? Boost leak?... I have a hunch it has something to do with the ignition... The problems are more noticable when the car is still warming up in the cold winter.
Any idea's?
Thanks guys
Art
Old Mar 3, 2009, 03:39 PM
RoadSpike's Avatar
A boost leak definitely could do that probably the easiest to test as well.
Old Mar 3, 2009, 03:51 PM
justa4banger's Avatar
is your bov vented into the atmosphere???
Old Mar 3, 2009, 04:16 PM
Evo H8's Avatar
I had a local turbo shop test me for a boost leak and they said no leak....
I am using a brand new Forge RS Diverter Valve... not VTA
Old Mar 3, 2009, 05:12 PM
exhaust leak??
Old Mar 3, 2009, 05:25 PM
Evo H8's Avatar
Originally Posted by justa4banger
exhaust leak??
Would an exhaust leak make the car sound any different? It sounds normal with exhaust...
Old Mar 3, 2009, 05:29 PM
SRT-TO-EVO's Avatar
Yeah it sounds like crap when you have an exhaust leak, you would tell.
Old Mar 3, 2009, 05:37 PM
Evo H8's Avatar
I had a bad 02 gasket before and it sounded like hell. I fixed that... sounds normal now but it runs incredibly rich with seems to buck or backfire under part throttle and inbetween high rpm shifts. What the heck could it be?????
Old Mar 3, 2009, 05:38 PM
what does your compression look like??
Old Mar 3, 2009, 07:06 PM
Evo H8's Avatar
Call me a fool... how do I check that? Is it a cheap easy check that a local turbo shop can run? Thanks.
Old Mar 3, 2009, 07:20 PM
Evo H8's Avatar
In the individual gears it pulls like a freight train and sounds great, but if I shift to the next gear at high RPM after WOT it bucks and runs rich as hell... what is it???
Old Mar 3, 2009, 07:21 PM
BlueDemon's Avatar
It could be a o2 sensor that has gone bad.
Old Mar 3, 2009, 07:23 PM
Evo H8's Avatar
I have a Buschur test pipe, which tricks the o2 sensor into thinking there is a cat... could that be the problem? I do not have a CEL...
Old Mar 3, 2009, 07:41 PM
BlueDemon's Avatar
I meant the front o2 sensor, sorry. Although, your description of the problem might indicate that the problem could be something else or a combination of things.
I been having the same problem with my car but right now I'm building my engine so I cannot tell you what could be the problem until it's done.
Old Mar 3, 2009, 08:03 PM
Evo H8's Avatar
I'm no pro but I have a feeling its ignition. How common is it to have so much hp/boost that we blow out our stock coils or ignition and the car runs crappy?
Quick Reply: Running richer and richer...
