How often do you miss shifts?
#34
my 3rd and sometimes 4th...but it has only been since I installed my exedy single disc. When I was on my stock clutch I could shift at any rpm at any speed and it was always smooth and nice. I miss that.
#35
Honestly don't remember the last time I missed a shift. It happens, but if you miss a shift frequently you may want to be more careful when shifting as it is most likely an issue with your technique. Once you have it down you honestly stop thinking about it.
#36
I've nicked 3rd or fourth a few times. It happens when I'm not being careful and/or shifting to forcefully. Mis-shifted once, at a low speed while tired.
It does not feel like it locks me out of the gear, rather its a timing issue ... letting out the clutch while the tranny is partially engaged. Definitely a driver error.
My miata used to lock me out of third if I was pushing it hard. I believe the differential bushings were too soft.
#39
Clutch is usually to blame for a lockout of most gears. As far as the grinding goes, thats usually driver error.
Keep in mind, the Evos gearbox is not a Honda design. Its a solid unit, but notchy and does not like to be shifted fast. Hell my 95 Integra GS-R with 170k on it is more tolerable for quick shifting than my 05 Evo with 27k is. Slow the shift down, and I guarantee the grind will disappear; well unless you have destroyed syncros or worse in the transmission already.
#41
What trans fluid do you fools recommend?
I'm looking at:
BG Synchromesh
Redline Lightweight Shockproof
Redline MT90
Pennzoil whatever it's called
AMSoil MTG
Royal Purple
I tried searching, but evom's search sucks latley.
I have Redline MT90 in my Mirage and love it. That's what I was leaning towards since have expeirence with it.
I'm not saying a trans fluid change will fix my problem, but I'm due for a fluid change this spring, so it doesn't hurt to try. If a trans fluid change doesn't fix it, then maybe I'll try adjusting my clutch or just remember to be more careful. When I remember to be careful, I'm usually miss and lockout free. But then you start to forget and get sloppy. And then BAM!!! Rev limiter. You look around and think "aww man I wonder if anybody saw that". 9 times out of 10... yeah, somebody did
On a happier note, my ETS UICP just came in today and my Perrin intake comes tomorrow! PPI Manifold should be here in a few weeks!
I'm looking at:
BG Synchromesh
Redline MT90
AMSoil MTG
Royal Purple
#42
I'm looking at:
BG Synchromesh
Redline MT90
AMSoil MTG
Royal Purple
I'm looking at:
BG Synchromesh
Redline MT90
AMSoil MTG
Royal Purple
Some say Redline is the way to go, and it might be. I will say this though; the stock fluid has never caused a trans issue. The same can not be said of other products. (not referring to Redline here, just a general statement)
#44
I just had my car out and everything went mega ultra smooth. No miss or lockouts. I was wearing my new dunks so I accidently slipped the clutch hardcore into second due to them being stiff and new. I couldn't feel the engagment oh well. I eventually got used to them. I still want to try another trans fluid. Suggestions?
#45
Kreeker
Feb 5, 2016 01:52 PM
LeeC
Apr 17, 2010 10:00 AM
