Evo 9.8cm or 10.5cm turbine?
cant you just look at the inlet of the turbine, theres some numbers too ...
( where the exhaust manifold goes )
I have both here, douple and single flapper 10.5 housings..
The TME 10.5 (built prior) has dual WG flappers. I know because I use one.
TD05HR-16G6-9.8T
TD05HR-16G6-10.5T
If numbers aren't visable you can tell the difference between the two side by side. The scrolls of course are larger on the 10.5. You might try plugging the jets with a styrafoam cup and measuring the volume of water it takes to fill.
TD05HR-16G6-9.8T
TD05HR-16G6-10.5T
Just looked at my 9.8 Hotside and here is the numbers.. Same as the posted one, only difference is the numbers up top. Your says 301, mines says 331
78-13010 115
78-13010 115
Hales
27
Apr 4, 2010 08:57 AM
LVSBB6
Feb 10, 2010 11:39 AM
