Vibrant maf adapter and amsoil fiter?
After reading the results from the air filter shootoutI have decided to go with the amsoil 4560 filter and the vibrant maf adapter. However the filter is much longer and the stock intake rubber pipe seems too long. Anyone running the amsoil filter which intake pipe have you used?
I've used the vibrant adapter with a k&n, it was about perfect length, any longer would not have worked because the stock intake is so long. You should be ok though, may just need to tilt it upwards a bit.
i have the vibrant maf adapter and a this K&N and it fits. the filter sits right behind the reservoir right there.
http://www.knfilters.com/search/prod...x?Prod=RU-4740
if the dimensions of the amsoil filter are the same it shouldn't be a problem.
using the stock intake pipe if the filter is any longer than 6" it will be tight (ie... not fit).
I'm running this combo. The filter hits the ACD reservoir bracket. I bent over the bracket slightly, I didn't use the gasket that comes with the MAF adapter, and I slotted the rubber mounting ring on the filter to clear the bolts that attach the MAF adapter to the MAF. With these mods, there was minimal deflection of the stock intake tube. The filter sits slightly canted upward.
http://vibrantperformance.com/catalo...roducts_id=389
Sweet.
Can anyone verify that this is the filter?
http://www.amazon.com/Injen-AMSOIL-N...3381592&sr=1-1
I live outside the US and so am limited very few online vendors.
Sweet.
i have plenty in stock of the EA-4560
GauGe
21
Sep 7, 2017 10:31 AM
FS[Northeast]: FP 84mm Intake pipe with MAF and Vibrant filter
michaelrc51
10
Dec 7, 2015 03:50 AM
metaevo
11
Nov 8, 2012 09:00 AM
