? For all running AFTERMARKET turbo
I just switched over from my stock 8 turbo to the greddy t67 kit. It is all installed. My question is..
Since the stock turbo set-up has the nipple for boost reference and my new turbo does not, where should i get my boost reference from?
I am using the factory one just to the right of the valve cover currently. I tried to use just that one and t-fittings for the vac line to make it work but it seems i need to have 2 references...
what are some options.. should i weld a nipple on the ic pipe, t off from the vac lines on the intake...
?? any ideas
also i use the boost pill for ecu controlled boost
?? any ideas
vaflyboi757
21
Aug 10, 2015 10:40 PM
