Fp Green turbo hot side
I have a problem with the turbine housing of my fp green. The turbocharger does not spool up. The trouble is in the wastegate of the turbine housing. It was milled by previous owner and now it leaks. I need new turbine housing. Is Fp green turbine housing the same with evo 9 turbine housing? Will Evo 9 turbine housing fit without fabrication?
thank you for replies
Easy enough to check....give it a shot.
We adjusted the actiator arm. It helped little but the trouble was not shot. the Turbocharger still did not spool up properly. I think it ileaks s due to a flap valve hole burn through
The turbine housing will need to be machined out for the green. A good machine shop would be able to do it. If you take the bad hotside in they should be able to machine the other 10.5 hotside to the same tolerances.
Brigganator
Feb 28, 2013 05:28 PM
