Converting tranny to run FWD (READ BEFORE YOU FLAME)
#31
just from what i have been told by shep. by chances it can leak if you make your own plate(bolt on plate for stock power or over stock)...but if that it would be better to weld the plate so its better off "what if it leaks". ive gone through this with other members and with fwd evo swaps...i know whats going on. just sayin even with so much power that center diff can break. id be more worried about the tranny then the tcase. im never going back tre for fwd tranny conversions, id rather get the fwd tcase.
#32
The only way I can see feasible to do this is you would have to stop the diff carrier housing from spinning. You cant weld the steel housing to the aluminum tcase body. Plus the spinning of the front diff housing(ring gear) is what throws fluid around inside the t-case to lubricate everything.
Regarding the plate, I guess it depends on who you talk to. When I asked shep about this 2 months ago, he told me he would fabricate a removable block off plate so that the tcase could be turned back to AWD if needed. Also my idea for making the plate to prevent leaks, was to buy a t-case center section that was junk, run it thru a ban saw to to take off about 1/4" worth of the flange and then weld the center of it up with plate, so this way I could bolt the whole thing on/off. I wont need to worry about the mating surfaces being true because the front mating surface is the factory center section, no reason it wouldnt seal right.
#33
Wow, thats interesting and unexpected. This info conflicts with the information I got. From the info I had, the transmissions on both the I4 and V6 was about the same. I was told that the only real difference was the bellhousing and they could be interchanged as long as you had the bellhousing for the motor. I know the gears on the inside are different ratios, but isn't it labeled as the same tranny? This was the info I found when I was looking into finding a way to use the 4g 6 speed with an I4 bellhousing. Would it be better to use the gears from evo and put it in the v6 tranny to keep it fwd or would that not help because you can't use the other parts you are worried about breaking after 400whp?
#34
#36
You didnt answer my question though, what are you talking about "locking up the T-case" do you have first hand knowledge of this or is it some hear say you heard from shep or someone else? I am interested to know how they can stop the center diff from biasing power to the rear wheels without welding it.
#37
The V6 tranny isnt going to mate up with the 4 cylinder engine without some heavy custom fab work on the bell housing.The V6 3g trans is the W5M51 gearbox like the EVO but it has a different bell housing, different gear ratios and obviously a different diff since its FWD. Whats weird is the 4 cylinder and 6 cylinder share the same diff but the gears/shafts are different. I dont see any benefit to running the EVO gears in the V6 tranny (if you did make it work) unless you were road racing. The taller final drive in the V6 tranny is great for high MPH for drag racing. The final drive in the V6 is 3.73
#38
The EVO internal parts arent really stronger per se. Like I said the input shaft, gears, hub/sliders and shift forks are all pretty much the same between V6 and EVO trannys. The output shaft even looks the same aside from the taller gear in the eclipse.
#39
Update.
So I got my trans and t-case back from DogBox Racing today. I am very happy with the entire experience with the guys over at dogbox, everything was done on time as promised, for a fair price and they really took the time to answer all my questions and concerns and explain to me exactly what was done. I plan to install the trans tomorrow, still cant run the car yet because im waiting on my new Peakboost HVS manifold (ETA 2 weeks), once I get that, I can fab up a new midpipe and replace the muffler and hopefully get this thing on a dyno. I will post more info on the feel of the tranny once its all together and I can get a few hundred miles on it.
#40
Update.
nudge120
Jul 6, 2015 12:53 PM
mr soul
Apr 30, 2012 06:31 PM
