Aluminum vs stainless steel
I tried searching and came across some differences covering heat characteristics stating aluminum will not retain heat as steel would and also weighs less, alike the nisei pipes. Yet the pipes from Buschur come in stainless steel. I was about to buy the ETS pipes when a friend recommended Buschur over ETS, yet they are both steel. Can somebody please comment on why they would recommend one over the other. I understand these two companies make good products and I don't want a company debate. I'm mainly interested in the content of aluminum vs steel or any differences between the Buschur, Nisei and the ETS pipes. The reason why I was going with the ETS was to have have a complete set up with their intake pipe and steel recirculating pipe.
1 Post
Josh
Unless of course you are running meth and don't want to worry about the corrosion factor. Also Stainless steel will maintain it's luster if you are doing shows. In addition to that, when you are running higher boost levels, the stainless will not suffer from metal fatigue like the aluminum can. this would require significantly more boost than stock.
Josh
Josh
You'd need to be running absolutely insane (i.e. beyond Pro class NHRA) boost levels before fatigue enters the picture as a consideration.
Aluminium will cool off much quicker than stainless steel. It will transfer the temperature from the hot side to the cool side much better.
Example: The air running thru the inside of the intercooler is much hotter than the air entering the front fascia of the vehicle, right? And so the heat inside the intercooler gets transferred to the outside air which is colder, right?
OK, so the hot air gets transferred to the colder air and gets cooled down by doing this, right?
Which air is hotter the air entering the throttle body thru the intake pipes or the underhood temperatures? Which colder air is absorbing the hot air?
1 Post
You are correct that you would have to be running very high boost levels to worry about metal fatigue. However, as stated above the aluminum pipes transfer heat faster than steel which also means they absorb heat faster as well, there by transferring it to the charge air inside. This means that under hood heat will transfer through the aluminum pipes into the charge air faster than with stainless steel pipes.
Also, I do like the ability to really crank down on the t-bolt clamps and not worry about distorting the pipe.
Josh
Typically Meth doesn't pool in the intake manifold when injected in the UICP like it does in the TB or at the point of injection. I have seen aluminum pipe with a lot of corrosion right around the bung where the meth injector is located.
Josh
Josh
The deformation thing I can see. But if you're cranking down that hard to avoid blow-offs, it usually means you have other problems with the plumbing that is causing you do have to do that. Like a bead that isn't aggressive enough or poorly fitting piping or an ill-fitting coupler , or simply an ape with a half inch drive ratchet.
GNR
17
Dec 11, 2008 11:17 AM
Jrod@Buschur
Nov 10, 2008 06:31 AM
Jedi@MaxumTec
EvoX 'For Sale' External Engine / Power
Oct 30, 2008 05:34 PM
