02 housings suck in cold weather
just to inform some of you that live up in the cold.
i installed a 02 helix housing wich i bought as part of the gruppes turboback combo.
this was done to 2 03 evo 8s
only difference was that one evo did not have the 02 helix housing installed and mine did.
the rest of the parts where installed ie helix test pipe downpipe and catback exhaust.
and i suffered all winter from overboosting where his had no such problems.
just wanted to inform those that dont know about this. regarding the aftermarket o2 housings.
im going back to my stockone now that i can get to wrenching without the snow freezing my *** to the ground
I experienced a bit of overboost in the cold as well. My EBC would flip out and drop it to wastegate pressure. Adjustment of both the electronic boost controller and the ECU solved the problem. Now it holds good pressure and I never hit fuel cut or boost cut.
