Symptoms of Blown HG?
Hello..Im just a bit skeptic..what are the symptoms of a blown HG?
I just got in my mind that I have a blown HG I dont know why I think this ..but
I have no overheating
No Milky Oil
No Smoke coming from exhaust...
so how can I know that I have a Blown HG? thanks
No Milky Oil
How do you not know why you think that? What's making you think that it's blown? Those are some of the usual symptoms, yes. The car may leak coolant on the ground. Do a compression test. My buddy just blew his, and the first 2 cylinders had very low compression. That pretty much gave it away.
loss of power because of loss of compression, milky oil, white smoke, overheating beacause of burning coolant, oil in coolant overflow tank, leaking coolant or oil from where the block and head meet. those are some of the symptoms of a leaking head gasket. best way to track down if this the head gasket is to do a leak down test
I will state that it is common for some 50K mileage evo's to leak oil in the back of the motor. It doesn't necessarily mean the gasket it blows but they do leak quite a bit. I took a look at the gasket it it doesn't look very well designed. It isn't as good as the evo 3 gaskets I've seen. I recommend anyone that plans on changing the head gasket to put a hondata liquid seal. That is all.
lghtngyello03
Feb 6, 2017 11:00 AM
FeRRarI eAtR714
Nov 17, 2005 03:32 PM
