2.3 just in, question about some smoke.
I just installed my new 2.3 and I am breaking in the motor. I noticed two things. First is that the S2 cams are now very noticeable compared to the original 2L motor. I donīt know if this is normal. Also, sometimes when I start the motor I noticed a greyish cloud of smoke from the exhaust. It smells as if it were LCD or transmission oil. I am using Brad Penn oil. There is no smoke while the car is running, only when I start it up and only sometimes. I have not tuned the car for this new motor, I was waiting for the break in period to be over. What do you guys think. Idle is poor too, but I think this is normal until I get the new tune.
You sometimes will get some smoking while the break-in , keep on eye on things .
you upped the displacement by 15% and haven't done anything to the tune? you should have a wideband on it and be setting your idle speeds, injector latencys, etc immediately. make sure that thing is running properly
Yeah you need to make sure the injectors are scaled correctly if they are new (bigger). Depending on your ECU, there are some idle settings that will help the car warm-up and idle better.
thanks for the input. The car runs very good except at idle as I mentioned and the once in a while smoke when I turn it on. I agree that it is so new that I need some miles in it to start thinking about what is going on. I also agree about the tune, but my tuner advices me to break in the motor and then get the tune in order to do thinks only once. I am really taking good care of the motor right now, very low boost and no more than 5000 revs. So I guess my old tune is fine for now until it is time to start stepping on it. Also, my new RED is here tomorrow so I will install it no Satrurday and I will keep on with the break in.
Thanks
Thanks
dude you need it tuned right now(break in map), your tuner should have sent you a break in map. If he doesn't know this, you should be looking for another tuner...
My car will occasionally blow some smoke when it starts, this is not likely oil based on color, smell, and duration, and I am 99% sure it is extra fuel burning from running rich either from last shutdown or on startup. Since my new tune and the warmer weather I have not noticed this, but your smoke may be fuel. However, you should definitely get the car returned after dropping in a stroker...
I just talked to my tuner and he said that when you do a new motor that includes new injectors ( different in size ) then the tune would be mandatory. He told me that since I am not putting a lot of load in the motor and I am keeping the boost low I am safe for the moment. He told me he could lower timing but he feels it is ok as long as I keep with the breakin. The previous tune he did was with the 880 injectors I have on right now.
You should be ok then if the injectors are scaled.
But, it doesn't hurt to get a few easy tuning things done now during break-in. Like the idle issues, I'd make him fix those now. And I would pull 3-4 degrees of timing out for break-in.
If the tuner is a friend make him get off his butt. If you are paying him, than you're the customer - he does what you want.
onlynamenotused
15
Oct 13, 2018 11:48 AM
moses_4g63
17
Oct 26, 2009 07:12 PM
Kmac
Jun 14, 2008 05:24 PM
