Evo 8 Mivec Conversion - specifics
Old Apr 15, 2009 | 12:33 PM
  #31
scheides's Avatar
EvoM Moderator
Awesome responses guys, pics would be fantastic. I'd like to compile any pics I can and make a big how-to on this. If it can be done with the dash in place that would be fantastic, taking it out for this swap seems silly; does the harness coming through the firewall go anywhere except right to the ECU? Does this also include the ODB2/flash ports? others?
Please, be as specific as possible! Thank you!
Old Apr 27, 2009 | 11:50 AM
  #32
phenem's Avatar
Well some things came up and my conversion is being put on hold, if anyone is interested in this please let me know I am getting rid of the entire setup needed to do this swap.
https://www.evolutionm.net/forums/sa...g-harness.html
PM me if interested.
~Zach
Old May 1, 2009 | 10:14 AM
  #33
silver_03_evo's Avatar
any new updates on this???
Old May 1, 2009 | 10:15 AM
  #34
i was comparing plugs and stuff there are three plugs that run down to the passenger side kick panel. but only one of the plugs fits so if any one has a solution let me know please.
Old May 14, 2009 | 08:38 PM
  #35
JakeTheVIII's Avatar
I just finished the swap and got her running. The swap was cake, I just overlooked a plug and it was running sloppy at first. Now it's all worked out, just needs a fresh tune.
Removal of the dash was pretty essential. A lot of plugs and wires back there that couldn't be reached with the dash in place.
I love it!
Old Jul 15, 2009 | 03:56 PM
  #36
skochur's Avatar
any updates?
Old Aug 28, 2009 | 04:39 PM
  #37
phenem's Avatar
I have an EVO 9 Head for sale on eBay in case anyone is interested in doing the swap. Contact me via PM and I can work a deal with you.
I am selling all the EVO9 head sensors needed to make this happen separately from the head unless you need both!
eBay link: http://cgi.ebay.com/ebaymotors/ws/eB...m=110429201598
Old Sep 10, 2009 | 09:46 PM
  #38
panem's Avatar
anyone know where i can find a piggyback plug and play ecu harness 8 to 9
so far i found this
http://www.stikiller.com/product.php?productid=16211
Old Sep 11, 2009 | 05:28 AM
  #39
phenem's Avatar
so far i found this
You cannot do that, you have to run a 9 ECU and 9 engine harness. The 8 computer will not control the MIVEC. If that won't happen then what's the point of swapping to a 9 head.
~Zach
Old Sep 11, 2009 | 04:43 PM
  #40
dhammans's Avatar
You could always run the few extra wiring bits yourself without having to go through the pain of doing the entire IX wiring harness swap.
Auto Sport Wiring in Texas makes fantastic harnesses. They will do custom orders, and pinouts. I'm sure if you told Richard what you wanted (EVO IX plugs on one end, EVO VIII plugs on the other, with a custom pinout) he could make it up for you real quick.
He custom made something similar for my Motec M800 install in an EVO IX and I had it in 2 days.
edit:
http://www.autosportwiring.com
Old Sep 11, 2009 | 06:55 PM
  #41
phenem's Avatar
You are missing the point here, the EVO8 ECU WILL NOT control the MIVEC sensors and will NOT run them. You NEED to swap to the EVO9 ECU.
Basically get an EVO9 wiring harness and EVO9 ECU, swap them out and you are good to go.
Old Sep 11, 2009 | 10:35 PM
  #42
dhammans's Avatar
What point am I missing? I've suggested that you use an adapter harness to run an evo ix ecu in an evo viii. Why else would I suggest different plugs and a custom pinout?
Not to be rude but perhaps you should re-read my post. The main issue is harness cost. If you can get one cheap from a parted out car that's probably the way to go. Otherwise a new harness from the dealer is way more than an adapter harness from ASW and a little scrounging at a junkyard for the appropriate connectors to add whatever else is needed wiring wise over the stock VIII harness.
Old Sep 12, 2009 | 07:00 AM
  #43
phenem's Avatar
I did read your post and I am trying to tell you guys, it's so much easier to swap out the harness. There have been two guys that already have done it this way and they suggested the same thing I am suggesting after attempting to use the 8 harness.
You can get a used 9 harness used for around $300, for $300 is that really worth all the headaches and not knowing you have the right pins in the rights places?
You are correct in saying that you "can" do it. But, at what cost and time. There are plenty of things you "can" do on any car with the right cost and time, but does it make sense? In this case no, buy a 9 harness and you are done. That's all I am trying to say, I just don't want to see someone attempt something that others have attempted and said how horrible it was and then waste all that time and money and end up having to buy a 9 harness anyway.
Old Jul 29, 2013 | 06:41 PM
  #44
rsonistxl's Avatar
I just got a built mivec motor for my 2003 Evo... What do I need to make it work? Evo 9 ecu and wire harness?
Old Aug 4, 2013 | 03:09 PM
  #45
heaveho's Avatar
Yes. .....if you can source a used engine loom and ecu, it's pretty straightforward.
Quick Reply: Evo 8 Mivec Conversion - specifics
