Which Engine Oil is the Best
Old Apr 5, 2009, 01:24 PM
  #31
apagan01's Avatar
Originally Posted by Excalibur
I have some amsoil 0w-30. I wonder how it stacks up against the competition.
its going to be hard to beat our SSO oils, they what you would call supper oil's, they have propietary chemical packages that most oils cant even dream about.
Old Apr 5, 2009, 03:34 PM
  #32
E85evo8's Avatar
amsoil FTW..no questions asked. IMO Amsoil is THE best synthetic oil $ can buy
Old Apr 5, 2009, 03:51 PM
  #33
joon82's Avatar
Wish i can get amsoil local. I've been using Mobil 1 with mobil 1 filter(damn local mitsu dealership closed down)
Cant really beat $29.99 5qt of mobil1 with filter
Old Apr 7, 2009, 07:53 PM
  #34
huevosrancheros's Avatar
Originally Posted by dambikeracer
My car has had 5w 30 Mobile 1 Syn oil with every change, every 3k miles. With other brands out there, is there anything better? With now running e85 and putting down about 420WHP should I change weight? Please give me your two cents. I was looking at AMSOIL and Eneos???
You should be running 10w30 Mobil, its in the car manual. U need 5.4qts exaxtly any less and you'll get a low oil light on your dash.
Don't deviate from whats recommended. Just save your money and stick with the recommended mobil 1. You can get a five qt. jug at wally world for twenty bucks.
Old Apr 7, 2009, 08:04 PM
  #35
PlanoEvo's Avatar
Really why Because your oil cap says so. Seriously mobil 1 isn't bad but there is better ie amsoil sso
Old Apr 8, 2009, 04:08 AM
  #36
bigben's Avatar
Really, I've never used 5.4 exactly and i've never had the oil light come on. Do you have any aftermarket parts on your car? I bet doesn't recommend aftermarket parts.
Old Apr 8, 2009, 05:44 AM
  #37
legal-z's Avatar
Anyone else ever read this? I switched to royal purple after reading this and doing other research.
http://www.animegame.com/cars/Oil%20Tests.pdf
Old Apr 25, 2009, 11:53 AM
  #38
mpfcc's Avatar
I used Eneos 5w-30 but I'm going to try the Amsoil on my next change.
Old Apr 25, 2009, 12:22 PM
  #39
DBallz's Avatar
Location: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Amsoil ss
Old Apr 26, 2009, 05:46 PM
  #40
Bob S's Avatar
It will take 5.3-5.4 qts if you blow out the oil cooler and lines.. Only talked to 1 person that has done that..
The test used is a Falex Bearing tester and there is no applicable place in an engine the relates to that test.
Use of the ASTM D-4172 or D-4172B 4-Ball would be better suited.
Also, RP has been asked to remove all advertising referring to any test reports as they are only from people reporting their findings and not through the use of Certified Tests.
Old Apr 26, 2009, 05:53 PM
  #41
apagan01's Avatar
they didn't even dared to test AMSOIL.
what company would dare to run 25,000k on their oil only AMSOIL plus is made
even more 35,000k on our SSO 0W30
Four Ball Wear Test
(ASTM D-4172B @ 40 kgf, 75°C, 1200 rpm, 1 hour), Scar, mm, .35
Old Apr 26, 2009, 05:56 PM
  #42
sparky's Avatar
Originally Posted by casper980
I just started running Elf/Total oil...100% synthetic Quartz Racing 10w-50 $7-8.00/L...
Do me a favor and check on the bottle to see if the TOTAL Oil is produced in France. I found this oil available to me locally, but in 5W-40.
Old Apr 26, 2009, 06:04 PM
  #43
wshihdnevo's Avatar
I use Brad Penn 20-50 Racing oil, if you can find it, its great stuff and its cheaper than Amsoil
Old Apr 26, 2009, 06:05 PM
  #44
apagan01's Avatar
I just started running Elf/Total oil...100% synthetic Quartz Racing 10w-50 $7-8.00/L I have only been running it for 500 miles, but so far the engine seems like it is running fairly smooth. I do not have much to compare it to though since I changed out cheap break in oil for the Elf. .
for about the same price we can get you dominator RD 15w50, oil designed to be abused
Old Apr 26, 2009, 06:06 PM
  #45
apagan01's Avatar
check out the Brad Penn, true Ball Wear test conducted, it had good amount of wear almost bouble than AMSOIL, even Red Line is doing better , tells me that cheaper is not always better when you are dealing with a turbo thats 2k and an engine thats almost 4k,,, lots of dough involved to save 1$ a quart
Quick Reply: Which Engine Oil is the Best
