Best Twin Disc Clutch?
#151
I'm back! and thanks to TedB and his comments on the SPEC P-Trim I was convinced and purchased it!
First off let me say how awesome SPEC company and their customer service is... Everytime I called they were so informative and friendly and really made you feel comfortable in purchasing stuff from them... SPEC gets a 7million A+ with me...!
Ok, I just picked up my baby with the new P-Trim installed.... Let me tell you!! Amazing, engagement of each gear is smooth and it actually feels so much smoother than stock. You can tell the difference between stock and the the P-trim, the P-trim is a little more sturdier and it shifts like butter, so far I've driven it for about 20 miles and no chatter whats so ever...
Oh and by the way, I did not stall the first time as some of my buddies thought I would since it's a different clutch...
I highly recommend this clutch to anyone... It's a beauty!
Will post when broken in...
#152
Boricua, thanks for the kind words and the great review. I am glad that we were able to assist you and that you are so pleased with the parts.
If you all have any questions regarding this kit please let me know and I will be happy to assist you. Thanks,
#153
In reading back over some of the posts here I noticed that Ted referenced that the St had organic disc material. This is incorrect information and I wanted to insure that you all had the proper run down on the materials used for each Super-Twin option.
SST- uses a hybrid disc design with Kevlar on one face and a Carbon-Graphite Puck on the other (for both discs).
PT- uses Carbon-Graphite pucks on both sides (on both discs)
ST- uses a full-faced Carbon-Graphite disc material on both sides (on both discs)
ET- uses a Sintered Iron material on both sides (ob both discs).
Each of our Super-Twins use one sprung hub disc and one rigid hub disc except the ET which uses two rigid discs. I hope this info helps. Thanks!
#155
No problem at all! I am glad that I could be of assistance. I have heard from a few folks that asked me to join and start posting with info. That being said let me know if you all need anything else. Thanks,
#160
l8r)
#162
Any progress on making the mini twin in carbon? I had spoke with an "insider" who inquired about it for me.
Aaron
#163
Aaron
