Best Twin Disc Clutch?
#93
yeah i have the exedy hd twin and take it into consideration they say the disc life is 3 months to 36 months depending on how you drive mine lasted about a year before i had to rebuild but i also beat the **** out of it. and rebuild cost 500 if your plates are good if not your looking at another 250 to 300 im not sure what the price on other rebuilds are. also if you get the hd and wnat to save some money in the long run as sooon as you feel the clutch start to go change the discs it will prevent you from having to change the plates do to heat spots from slipping or a welded tob in your wedge collar ha take it from my f up ha. but other than that deff recomend it besides the rebuild deff was worth it
#99
This is true if you have a QM or Tilton. In my case, the noise was just one thing about these clutches that made them unbearable. Aside from the terrible rattling that's bad enough to devalue the car (IMO), if you live in the hills, you will be sorry.
The SPEC Super Twin I have presently is the only clutch this car will ever see from this point forward, period. It is a push type (no additional conversion required), has stock like pedal pressure, is easy to drive as stock, is rated for more torque capacity than you will generate, and is relatively quiet.
#100
I have a similar clutch (PTT 7.25) with sintered bronze material and it is an amazing clutch to drive besides the noise. When adjusted properly it will be easy to drie and it shifts SOO awesome. However, I am wearing the disks out about every 7-8K miles. I have gone through two sets of disks in 15K miles. This is in a mid 12sec street car daily driver. I will not break and it will hold the power but it wears out quickly. The sintered iron material is longer lasting but the bronze material that PTT uses doesnt wear any of the mating surfaces and it didnt need anything but disks when I took it apart the last time. Also PTT offers free rebuild labor on all clutches for life. You pay for parts thats it. I was considering trying the organic disks this next go round but I think I will stick with what I know works as this one does.
#102
That is strange...I normally got 15-20,000 out of my QM before it would start slipping. And that was with lets say "spirited" driving. Although I only launched of the 6000rpm 2 step when needed...Lots of daily driving and drag racing. I got 8,000 out of it with a reused floater plate that I should have replaced but I needed the car back and didnt have time to wait for a new floater plate.
#104
breaking in a Spec SS trim twin disc and can say that pedal feel is just like stock, and no "extra" noise that is usually attributed to twin discs. This Spec twin is the "entry" level twin and rated for 900lb/ft of tq. Both discs have one side that is full faced kevlar and the other is a "carbon metallic" 6 puck..pretty trick!
#105
