Looking to upgrade from the pt67
The title pretty much says it all. I'm currently running a 2.4l (fully built) with a precision 6776rsp. The thing makes mad power on race gas and hits full boost around 5300rpm. Current setup on racegas will be around 7xxwhp. BUT I need to know if there's something better out there since everyone's always coming out with new turbos.
My main concern is power once boost hits, I'm less concerned with spool although it's still a factor. Are there any turbos that...
1. would spool around this time but make noticibly more power?
2. spool earlier and make same/more power BUT hold til 9000rpm?
3. spool later and make enough power to compensate (keep in mind redline is 9000rpm so power would have to be early enough to be useful)
Thanks for any help
Thanks for any help
The Precision billet 6765. To answer the question of how it compares to your turbo, the compressor is the same size but a new design for more power. The turbine is also the same size, but is also an updated design for a little quicker response and better airflow.
