9 turbo on an 8 only hitting 24psi...
Shim the spring inside the boost controler with some paper or a foam ear plug, strech the spring a little bit, turn down the boost controler to the lowers setting and see what it hits. WATCH THE BOOST GAUGE AND WIDEBAND. Also your car should be tuned at the raised boost and have a Walbro 255hp fuel pump before you try to do this.
