4g63 turbo block in Evo 8
differences between a 7 bolt 4G63T block(1997 eclipse turbo) vs. a 7 bolt 4G63T EVO 8
Hi,
does anyone know what are the differences between a 7 bolt 4G63T block( from 1997 eclipse turbo) vs. a 7 bolt 4G63T EVO VIII block?
are the crankshafts and rods the same? im sure the pistons are not. any other differences? coz im planning to build a short block for turbo use. I have a spare 4g63T ( from 1997 eclipse turbo) block just lying in my garage. if the crankshaft and the rods can be used for 400+whp then i can just buy ACL race rod and main bearings plus ... + EVO 8 head with hks camshafts..
thanks in advance for your comments
Max
Max
The block itself different. Where the transmission bolts to the block is completely different between the 2 blocks. The 2G block has only 4 bolts to hold the transmission on, and the Evo block has 5. I just did a motor on a 97 4g63, and on an Evo, and had both block side by side, and they are not the same. Hope this helps
Attachment 132566
evo block piston hole lubrication
Attachment 132567
eclipse piston hole lubrication
this is not problem but i am remove balancer shafts and modify oil pump but need big oil pressure...
Attachment 132568
difference in rods... evo rods is better..
Attachment 132569
eclipse turb piston
Attachment 132570
evo VIII piston
Attachment 132567
Attachment 132568
Attachment 132569
eclipse turb piston
Attachment 132570
evo VIII piston
The guy above must have been working on a 1g or a 2g with a 6 bolt swap. The 6 bolt motors(pre 92.5) have only 4 tranny bolts. The 7 bolts have 5. However. On the front side of the block where the evo starter would go. The dsm 7 bolt's front 2 tranny bolts are too far appart to accept the evo starter plate/tranny.
Oil/water pumps should be the same. I could go downstairs right now since i have both blocks sitting waiting for builds.
Why on earth would anyone put a dsm 7 bolt in an evo is beyond me. Crankwalk>than cost of dsm 7 bolt savings.
If you wanna save some money instead of paying ridiculous evo block prices just get yourself a 4g64 out of an eclipse. Those blocks can be had for ~$100. So the money could go to better things. Like forged internal goodness.
