Tranny
Old Apr 8, 2009 | 08:27 PM
evo4l's Avatar
Tranny
hey guys,
so i am an idiot. I just got my tranny rebuilt and am going to install it and before i started i was looking over everything and it was my dumb fault to put the pressure plate on the shaft and lock it to my TOB. I know you have to pull the clutch fork over and pry in between the collar and the TOB to slide it off but it is NOT budging! I obviously had to do that procedure to get the tranny off but now when its off i cannot get it out and you would think it would be easier but i am an idiot lol. Someone tell me im forgetting something or give me some advise thanks alot.
Old Apr 8, 2009 | 08:28 PM
PeteyTurbo's Avatar
That sounds like something I would do haha.. Keep at it, it will pop off..
Old Apr 8, 2009 | 08:33 PM
evo4l's Avatar
lol well ok but i have been working on it for like an hour and it almost seems like im wrecking that collar idk it looks like im starting to bend it
Old Apr 8, 2009 | 08:38 PM
PeteyTurbo's Avatar
I hate that clip..I ruined my last one, but the two I did before that came off no prob.. Might want to start looking for another clip just in case
Old Apr 8, 2009 | 10:32 PM
dancarroll0283's Avatar
So is the tranny still on the block??? I have a little trick that I use when getting the 2 apart. Half the time, I can't get them apart either.. What you can do is remove the boot that goes around the clutch fork, if you pull the fork all the way towards the mounting spot on the tranny were the slave cylinder bolts you can get a 1/4 drive 12mm short socket in there, and remove the pressure plate bolts one at a time, and eventually get all the bolts off and the pressure plate will come off with the tranny. you can call me if you need more help. (505) 948-3276. Daniel
Old Apr 9, 2009 | 06:47 AM
evo4l's Avatar
no man, it is so stupid the tranny is just layin on the ground. i got it off the block fine and before i was going to put it back it i was just screwing around and set the pressure plate in the tranny and it clipped on the TOB. I guess i will just keep trying to pry it.
Old Apr 9, 2009 | 06:00 PM
evil-evo's Avatar
try lifting one side of the clutch as u pop the ring off if u havent tried that already
Old Apr 10, 2009 | 09:04 AM
evo4l's Avatar
clutch/tranny
hey so had a post earlier about not being able to get my pressure plate off my TOB. well i still havent got it and i am pretty sure i wrecked my wedge collar. does anyone know where you can get a new one? also how i can get the pressure plate of my TOB its still on and i cannot get it off i worked for hours on it.
partyboy1122
18
Oct 30, 2011 06:57 AM
rooney08
11
Apr 16, 2011 04:40 AM
GrimCreaper
Apr 12, 2010 09:52 PM
theLAM
Mar 27, 2010 09:14 AM
AzNeVo8
Oct 6, 2005 10:37 PM
Quick Reply: Tranny
