Wastegate overboost and boost creep
it's a positioning problem....when you hit higher RPM the exhaust gas doesn't want to turn at a 90* angle and it follows the path of least resistance which is right into the turbo, only way to fix it is give the gate more priority on the manifold
like tial said the piping after the wastegate could cause this as well. I ran into this on a O2 dump for the stock turbo. The gasses had to make too sharp of a turn after the wastegate and it couldn't bleed off enough exhaust through the wastegate, which led to this kind of overboosting.
