broken spark plug, head damage?
So just for the hell of it me and my friend decide to do a compression test on my motor. Oh and my car only has 11k miles on it, bought it with 5k miles. We take out all the spark plugs and the Cyl 2 plug has half the ground strap missing!! Like theres no metal above the electrode only very little right after the "hook" part. So we do the compression test and the numbers came up like this...
Cyl 1 - 140
Cyl 2 - 125
Cyl 3 - 145
Cyl 4 - 135
I really couldn't find what spec is supposed to be but I found it for a 2g dsm (7 bolt) standard was 178 and service limit was 133. Im so pissed right now. I dont know what to do from here either bring the car back to bone stock and take it to the dealer or just take he head off and send it out to someone like Buschur to get it built. Im pretty sure theres gonna be head damage like the valve seals or valves themselves and theres probably some pitting on the top of the #2 piston too if not others. I hope theres no more damage than that. I need to have a cyl leak down test done anyways. The weird thing is is that the car was running fine, no miss firing or anything to suggest something was wrong. What should I do.
Cyl 1 - 140
Cyl 2 - 125
Cyl 3 - 145
Cyl 4 - 135
ive heard if compression is 5-10% away from each other, your in the clear
i see that you only have 11k, id try to contact people on thier compressions.
could be alot of dmg for 11k
If the car is running fine, put in the new correct plugs and keep running it.
If you're truly ****, repeat the compression test. Do a leak down test if you want to confirm condition of the valves, etc. Take a look with a borescope if you want to see whether there was any damage from the loss of the single spark plug partial electrode. I'd not worry too much about it, unless you're having problems...
ok, im going to let the car get to full operating temp and redo the test with my friends tester, im kinda doubhting my tester for some reason. With it warm it should help the rings seal a little tighter so I can get more accurate numbers and just to see if theres a difference. Im still dumb founded that the car wasn't making any kind of weird conditions or noises and how it wasnt miss firing. Im thinking that if by some chance the piece broke off and flew out with the exhaust gasses after the combustion cycle and miraculously missing the valves, seals etc. there must be damage to the exhaust wheel on the turbo. Maybe some scuffed/chipped/dented fins.
no because the car is on jack stands since I changed all the fluids, changed my springs and just in general was doing alot of work to it. This was just a spur of the moment kinda thing and when I pulled that plug out I was like wtf?
Warming the car up is a must for compression testing. THis is part (if not all) the reason the numbers are low.
The car has a burned valve. I can almost guarantee it. Your cylinder was getting far too hot, which burned the valve, which is causing the low compression. It also burned the spark plug, which is why the electrode has melted away. If you change out the plug, it will be bad again within a few weeks.
ok well I put them back in and got the car upto operating temp and redid the test.
cyl 1 - 152
cyl 2 - 140
cyl 3 - 155
cyl 4 - 149
I still dont know what spec is for the IX.
cyl 1 - 152
cyl 2 - 140
cyl 3 - 155
cyl 4 - 149
