Rev limiter - stocks springs on HKS 272s
what do you guys think i should set the rev limiter at if i'm using stock springs on HKS 272 cams. it's my daily driver and i only plan on redlining it once in a while and bringing it to the track once a year?? also, has anyone actually seen valve float on a 4g63 before??
I've revved out BC 280 cams on stock valvetrain over 8000rpms for over 20k mi. Is it smart? No.
I have a GT35R. 272 HKS's, and my rev limit is set to 8000 but my shift lights are set at 7000, so with my slow reaction time. I log my shifts in the 7200-7400 range depending on gear.
On a side note hopefully you are not on a stock turbo. If so 8000 is way out of it's range.
