Wow - Looks Like I've Toasted a Rod Bearing
Old Jul 29, 2009 | 05:32 AM
  #196
Ted B's Avatar
The only outstanding issue involves the size of the throttle shaft wheel, and it takes all of about 1 min to replace it on the car. I'm working with Hypertune to resolve it right now, so it will soon be a non-issue, one way or another.
Old Jul 29, 2009 | 06:14 AM
  #197
zedevo's Avatar
Good Luck ...
Old Aug 27, 2009 | 06:49 PM
  #198
JC evo1's Avatar
any updates Ted?
Old Aug 28, 2009 | 06:11 AM
  #199
Ted B's Avatar
Still awaiting the replacement Hypertune TB ...
We've determined that the spring pressure on my Hypertune TB is enough to significantly compress the rubber grommet at the end of the throttle cable that is attached to the pedal. When this happens, it reduces cable travel significantly.
Aside from that, the engine is running very well, and I am tuning and tweaking as I have time. The CNC port job and 12mm lift cams really make the 2.0L engine feel torquey.
Old Aug 28, 2009 | 12:28 PM
  #200
binh's Avatar
Still waiting? Jesus christ. At this point slap on a ported stocker and be done with it!
Old Aug 28, 2009 | 12:36 PM
  #201
TTP Engineering's Avatar
Or better yet Ted...
https://www.evolutionm.net/forums/ev...sting-ttp.html
Old Aug 30, 2009 | 07:03 AM
  #202
Ted B's Avatar
The Boomba is the fallback option. I just dread the idea of pulling the manifold and sending it back to Tom of DI to be reflanged. We'll see if the Hypertune TB is waiting when I return home on Wed.
Old Aug 30, 2009 | 07:17 AM
  #203
Craig King's Avatar
Bummer - hope you can get it fixed and back onto the road soon.
Old Aug 30, 2009 | 07:19 AM
  #204
Ted B's Avatar
The car is on the road and running well, it's just that so long as this TB has excessive spring tension, it cannot open the throttle valve to the full WOT position.
Old Aug 30, 2009 | 12:26 PM
  #205
bambooi's Avatar
That is no fun at all. Need to fix that TB so you don't damage your throttle cable.
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
Cigaretteeyes
Jul 17, 2017 06:14 PM
xxorathaa
May 7, 2017 06:36 AM
kaj
Jan 27, 2017 03:45 PM
DanJ
Sep 6, 2013 03:01 PM
Quick Reply: Wow - Looks Like I've Toasted a Rod Bearing
