Just changed clutch line and bled it, have question
So I bought the WORKS stainless steel clutch line and just got around to installing it tonight. PITA!
I followed the detailed write-up on EvoMoto (including removing the restrictor plate and spring), with a buddy of mine operating the clutch pedal while I opened and closed the bleeder valve as necessary. He'd push the clutch in, I'd open the valve, wait for flow to stop, then close the valve, then he'd let the clutch pedal up. I kept my eye on the fluid level in the reservoir and topped it off (up to the top of the fill neck, not the bottom) when it would get close to the bottom of the fill neck. Rinse and repeat until I saw no bubbles coming out of the bleeder screw. None of the line fittings are leaking at all.
Now when I drive the car, the clutch pedal seems to depress "easier". Is this normal? I expected clutch feel to be more or less the same. The action seems good and it comes back up perfectly when I release it. Also, there seems to be about 2-3 inches of travel at the beginning of pedal movement where it is VERY easy to push and THEN the clutch pressure increases. Isn't that a sign of air in the lines or is this normal for having removed the restrictor? I swear we pumped and pumped and pumped and no air was coming through that line. We even gave it the goods one more time there at the end just to be positive.
Thoughts?
Thoughts?
Sounds like air in the line still. I would go to an autoparts store and get a vac bleeder. So you do not have to pump the clutch at all, but rather pull the fluid through. That will insure you get all the air in the line.
I also think you still have air in the lines this giving you that smooshy pedal feel. Air compresses really well and fluids do not. It could also be that your clutch pedal is out of adjustment. Have you tinkered with that at all?
I have the Motul Power Bleeder so I'll be using that. We didn't use it on the clutch line because I left it at my house by accident and I didn't feel like running home.
