Oil on exhaust manifold stud???
Old Jan 24, 2011, 01:31 PM
revvin9k's Avatar
Gray Mopar is your friend. And yes it works very well.
Old Jan 24, 2011, 02:12 PM
Mattsubishi's Avatar
All my DSM's have done this to. It's never been severe enough to light on fire though in my case.
Old Jan 24, 2011, 08:37 PM
shangai's Avatar
wich redloctide? do you know wich stud for sure has oil on the back?
Old Jan 27, 2011, 07:48 AM
shangai's Avatar
Help?
Old Feb 4, 2011, 11:01 PM
shangai's Avatar
since no body helped me. im going to help everyone. All the lower studs reaches the inside on the head. so you should take them all out and use blue locktide an put them back.. not onle the one on the center.. ALL OF THEM!!
Old Feb 5, 2011, 09:45 AM
revvin9k's Avatar
lol, we told you to just tighten em all up, I used Mopar RTV, i'm sure the Loctite would suffice as well.
Old Feb 5, 2011, 02:21 PM
kekek's Avatar
Loctite is not a sealant. The RTV is what should be used. Loctite may work but is not an optimal solution. The "blue" loctite is medium strength and has less holding strength than the "red" which is intended for permanent installation.
Another note, if the threads are not cleaned of the oil the blue loctite may not set properly. Also the blue requires a minimum of a 6 hour set prior to being exposed to any fluids. Loctite 242 is the standard "blue", but there are other variants. Another popular one is 243, which is designed to be more oil resistant than 242.
I used Hondabond on mine. It's an RTV silicone sold by Honda/Acura dealers and supposedly good to 600F.
Old Feb 5, 2011, 06:34 PM
shangai's Avatar
so far so good. i did cleaned the holes
Veronica
May 18, 2017 01:09 PM
Hiboost
Evo X How Tos / Installations
16
Feb 27, 2016 03:33 PM
XT Redline
Sep 7, 2014 08:56 PM
boostnMA
Oct 26, 2012 07:21 PM
omniprobe
Jun 6, 2011 01:10 PM
Quick Reply: Oil on exhaust manifold stud???
