Oil on exhaust manifold stud???
i just recently found oil on the center lower stud/bolt that connects the exhaust manifold to the cyl head. Nothing above it or below it... just the stud coming out of the head is soaked in oil. STRANGE... its like its leaking from the hole where the stud resides? Has anyone experienced this? Is there an oil galley/passage that runs near the exhaust manifold studs in the head? Could it have possibly cracked leaking oil to it? No visible cracks on the head and its not like this stud is sitting any deeper than the rest. Was never over torqued either.... just really weird.
No ill effects yet... but i can't see how this could be good...
-Tom
-Tom
The exhaust mani studs are threaded thru the head and into a oil gallery. There is a pic somewhere on evom proving this.
Just put some high temp sealant on the stud and put it back in.
Thanks Guys!! I fixed it by retorquing the stud/bolt. its not leaking anymore. What an odd thing to do... the stud go through an oil galley? Anyways.. good to know now!
i just had the same proplem and the oil gose in fire and A cloud of white smoke when i open the bonnet i fund this studd is out i was thinking my blok is crash. but thank for evom it's have the anser for any proplem
JUST REMOVED THE MANNY AND FOUND MY GASKET FULL OF OIL.. AND THE STUD NEAR THE 14MM NUT WUTH 12MM NUT WAS LOSEN ( TIMMING SIDE) . I WAS WONDERING, WICH OF THE LOWER STUD RUN INTO THE OIL PASAGE? sorry for the capls.. i have the caps lock on.. stupid fingers
any help?
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
