2.3l strocker w/ i-beam ques.
hey, so im assembling my motor and have a small problem. its a 2.4l crank with i-beam rods and when i turn the crank the rods are hitting the cylinder wall. i know you have to knoch out the inside for the crank but has anyone ran into this problem due to the thick rods?
if so what did you do? im prolly just going to put a small knoch at the bottom of the wall sence it wont harm the perfromance of the vehicle.
thank you
martin
thank you
martin
Hahahah...dont all jump in at once.
I use Pauter rods for my builds (mostly) which are very very wide at the base and even on the 2L i take a bit off the edges of the sleeves to ensure a fair gap for swing over.
As long as you are reasonable and dont take lots off you will be fine. Try stick to a low angle and not go too far into the sleve. Clean the block out well. I usualy mask it up in the area i die-grind so i can control the mess. Also makes it easier to clean up.
Were you to have used Pauter rods on a 100mm stroke you'd have to take quite a bit off there and as there is an oil channel on the one side you need to be cautious.
A
A
lol it's not really a "specialized" operation. I did it myself, ya just grind off enough so that your rotating assembly can rotate freely. Don't take off TONS of material, but take off enough so it will NEVER hit even while at hot temps.
Howulikemyevo
Mar 2, 2016 11:10 AM
FS[Northeast]: Manley I-Beams
real fast
Jan 20, 2016 08:53 AM
Howulikemyevo
Sep 28, 2015 08:58 AM
Tonba
Jun 14, 2009 05:54 PM
